Set / update the layout names via LISP
This widget could not be displayed.
I would like to set and update the layout names in DWG via LISP.
At the beginning, I don't know how many layouts I will need and in the case of revisions / changes, new layouts can be added at any time.
I found a great LISP from Markus Hoffmann (many thanks to CADmaro), where after (my simple) adjustments only code sequence for the maximum number of layouts is missing (marked as "(missing code for the highest layout number)"). I can't find this definition and ask for your help.
The layout names should be: e.g. Page_1from8, Page_2from8, etc.
;Set / upgrade layout names to format: Page_XfromY
(defun c:RenameAllLayouts ()
  (vl-load-com)
  (vlax-for i (vlax-get-property
                (vlax-get-property
                  (vlax-get-acad-object)
                  'ActiveDocument
                'Layouts
    (if (/= 0 (vlax-get-property i 'TabOrder))
      (if
        (vl-catch-all-error-p
          (vl-catch-all-apply
            'vlax-put-property
            (list
              i
              'Name
              (strcat
                "Page_"
                (itoa (vlax-get-property i 'TabOrder))
		"from"
         (princ
           (strcat
             "\nLayout "
             (vlax-get-property i 'Name)
             " can't be renamed, konnte nicht umbenannt werden, because the name has already been used."
;;; Quick command ALU
(defun c:ALU ()
  (c:RenameAllLayouts)
(princ
  "\n\"ALU.lsp\" was loaded. Enter \"RenameAllLayouts\" or \"ALU\" to start."
(princ)
Many thanks for your help in advance.
Replies (8)
CodeDing
@Anonymous ,
I'm not very savvy with the "vl-" commands. Here's my take. It uses a function I created a while back.
(defun c:RenameAllLayouts ( / LayoutListOrdered cnt len name lays)
  ;Helper Function(s)
  (defun LayoutListOrdered ( / dLays lays oLays cnt)
    (setq dLays (cdr (assoc -1 (dictsearch (namedobjdict) "ACAD_LAYOUT"))))
    (setq lays (mapcar '(lambda (l) (cons (cdr (assoc 71 (dictsearch dLays l))) l)) (layoutlist)))
    (repeat (1- (setq cnt (1+ (length lays))))
      (setq oLays (cons (cdr (assoc (setq cnt (1- cnt)) lays)) oLays))
    );repeat
  );defun
  ;Prep
  (setq cnt 0)
  (setq lays (LayoutListOrdered))
  (setq len (itoa (length lays)))
  (setvar 'CMDECHO 0)
  ;Rename Layouts
  (foreach lay lays
    (setq name (strcat "Page_" (itoa (setq cnt (1+ cnt))) "from" len))
    (if (member name lays)
      (command "-LAYOUT" "_r" name (strcat "tmp_" (itoa cnt)))
    );if
    (command "-LAYOUT" "_r" lay name)
  );foreach
  ;finish up
  (setvar 'CMDECHO 1)
  (prompt "\nLayout Naming Complete.")
  (princ)
);defun
Best,
~DD
Need AutoLisp help? Try my custom GPT 'AutoLISP Ace':
https://chat.openai.com/g/g-Zt0xFNpOH-autolisp-ace
Hi DD,
many thanks for your help.
Your code works perfectly and is also easier than my example - great school for me, a beginner.
Best regards from Germany
PS: which method / tools do you use for LISP?
cadffm
(itoa(length(layoutlist)))
Or you saves the number one time before you walk thru your layouts:
(Setq nLayouts (itoa(length(layoutlist))))
Then you need just
place this:
nLayouts
Sebastian
CodeDing
@Anonymous ,
I use:
- AutoCAD
- Notepad
- Developer Help Tools
- Lots of practice
Once you become familiar with the language, your ability to apply it to AutoCAD just comes naturally.
Best,
~DD
cadffm
Autocads VLIDE
Das AutoLISP Kochbuch (oder autolisp.info)
F1 Help (Lisp and DXF Reference)
In German:
Nehme dir kein Ziel vor, sondern arbeite die nächsten Wochen das Tutorial durch.
Dieses Tutorial vermittelt grundlegende Dinge, neben ein paar AutoLISP-Funktionen zugleich Wissen wie man programmiert.
Das wichtigste ist aber die Info wie der Syntax ist, was es bedeutet und wie man sich weiterhelfen kann.
Gehe erst auf die nächste Seite wenn das wirklich sitzt, die so vermittelten Grundlagen sind Gold wert.
<Geschichten zum Kopf schütteln lasse ich an dieser Stelle mal aus>
Sebastian
Sea-Haven
Hi if you have a look at this it will return layout number directly so no need for a defun tabs is the layouts via vl
(setq doc (vla-get-activedocument (vlax-get-acad-object)))
(setq tabs (vla-get-Layouts doc))
(vlax-for lay tabs
(setq x (vla-get-taborder lay))
rename layout using x
valentina_hadla_work_ecu
Community Visitor
Community Visitor
HELLO CD,
thank you for your help, it worked perfectly
can you please help me to change the start number of counting, I've tried
I managed to change to change text  by replacing ("page_") with the name I needed
and delete the part ("from")
cadffm
(setq cnt 0)
Sebastian
