Set system variable xclipframe to 0 (zero) in multiple drawings
josue777torsan
Message 1 of 29
josue777torsan
Is there a way to set system variable xclipframe to 0 (zero) in multiple drawings?
@Lee_Mac
@Kent1Cooper
Architect, CAD Manager in Mexico City
Replies (28)
Message 2 of 29
Kent1Cooper
Doing things to multiple drawings is not something I find myself needing to do often enough to have a ready answer, but others have raised similar questions before.  Put "multiple drawings" in the Search window and you'll find many threads with ways to do it, some of which you should be able to adapt to that particular setting.
Kent Cooper, AIA
Message 3 of 29
pbejse
@Lee_Mac
@Kent1Cooper
Think the rest of us should sign up..
... where do we register @josue777torsan ?
Message 4 of 29
roland.r71
@Lee_Mac
@Kent1Cooper
Yes, where indeed. I actually know the answer to this one. (it's one of my expertises on this forum as it would seem 😁
Although I wasn't called for, might i suggest a few threads or even my own lisp-program to do all the fileselecting and running the commands or lisp needed? - or would that be out of line?
Message 5 of 29
pbejse
If it helps the OP go on ahead @roland.r71  👍
Message 6 of 29
roland.r71
Alright, then lets start with the absolute basics:
My example (proof of concept) code
(defun C:MF (/ filelist file)
   ; create list with filenames
   (setq filelist
      (list "C:/Lisp/TestDWG/Drawing1.dwg"
            "C:/Lisp/TestDWG/Drawing2.dwg"
            "C:/Lisp/TestDWG/Drawing3.dwg"
   ; activate single document mode (required for sequential processing, using a script or lisp)
   (setvar "SDI" 1)
   ; Turn off the (re)intialisation of lisp with each drawing. Meaning: lisp functions will stay loaded.
   (setvar "LISPINIT" 0)
   ; for each file in the list
   (foreach file filelist
      ; Open and process it.
      (command "_.fileopen" file) ; open it. (note: this is where things can get ugly)
      (setvar 'xclipframe 0)      ; <- The requested sys var change
      (command "Qsave")           ; save it. (note: which too can be a problem. (if read-only))
Add (& replace) the filenames inside the list and this piece of code will already suffice.
IF there are no 'complications'. Like read-only files and such.
If you where to expand on that, to fit EVERY situation, you get something like my "Multi File Tool".
I'll ellaborate on that in my next post.
Message 7 of 29
roland.r71
My MFT.LSP or "Multiple File Tool".
This is a lisp-program (its to big to just call it a function, imho) that will allow you to select files (in pretty much any way you might think off) & select a lisp file and/or enter a macro, script code or just 1 or more commands (command ...) to be executed on each file.
When starting the function you get the main dialog:
Here you can set the various options how to handle certain situations, progress bar on/off & logfile.
supply a .lsp file to load and/or supply the code you wish to run.
For the example i already added the requested sysvar change as code. Which should be enough in this case.
The code can be edited inside its own edit window:
Short of full fledged lisp functions you can enter almost anything. (including macro's !)
Which came to be with some help from @john.uhden
After (or before) that you can select your files:
You can add files in any way possible. Add (all) currently open, read a single dir, a tree or even from a file (Note: This would require import filters for most applications, like excel). You can save/load/edit the filelist. Change the order or just sort it alphanumeric. It allows for filename wildcards too. (only for adding. Not to filter the list itself)
During the process it will check each file real-time (read-only? open? openByOther? ...) and allow you to take action.
There is only one minor 'downside' to it all (if you can call it that): it requires DOSlib to run.
You can find some more information on the function and how it works >here<
Message 8 of 29
pbejse
You can alos consider this is five star tip from  Andrea Andreetti , Use Publish To Batch Run Commands
Once you are aware of this capability, you cannot get this out of your head.
Message 9 of 29
pbejse
That looks awesome @roland.r71 , I think you got a winner there 😊
Message 10 of 29
andkal
Im afraid line "(setvar 'xclipframe 0) " will be performed still the session you run the your defined MF command.
You can go this way too:
1) write and save such short lisp file :
(setvar 'xclipframe 0) (command "_qsave") (command "_close")
2) add it to Startup Suit in Load Applications dialog window (APPLOAD command).
3) select all dwg files in which you want to set Xclipvariable and drag and drop it to opened autocad.
4) after process is done delete Lisp file so it wont be found when autocad opens a file
5) delete the path from Startup Suit
This method will have a disadvantage of that it can ocupy some time for opening and saving each drawing.
• www.autolisps.blogspot.com - Productivity plugins for Autocad and Autocad MEP
• Autodesk AppStore
Message 11 of 29
roland.r71
Thnx!
Message 12 of 29
roland.r71
I would need to test it to be sure, but this here has worked with everything so far.
It isn't even the same session. it opens the files in sequence using SDI. Only the lisp routine keeps running.
Executing lisp code within each drawing. (and the script code entered is EVALuated)
Message 13 of 29
john.uhden
Huh? What did *I* do?
But it must not have been all that bad since no one has come to arrest me
(yet).
John F. Uhden
Message 14 of 29
roland.r71
Well, actually, you went on a vacation and never came back 😄
Message 15 of 29
roland.r71
...but before that you helped me out on getting my 'script/macro/commands' option running smoothly 👍
Message 16 of 29
john.uhden
Wait a second.  I DID come back, although it was in the middle of a dark black night, so no one noticed. Thank goodness @scot-65  was around to help you out.  I think you might want to name your work as Scriptify.lsp.
Looks like this year there will be no vacation.  What for?  I haven't been working anyway. But thanks to that extra $600/week I have been better off than when I was working.  I actually spent some of the stimulus money on a robotic pool cleaner.  It's miraculous.
John F. Uhden
Message 17 of 29
Sea-Haven
Why not just chuck aeccoreconsole into the mix.
aeccoreconsole dwg1 script
aeccoreconsole dwg2 script
aeccoreconsole dwg3 script
The script would be very simple
qsave
Lee-mac has a OBDX wrapper may be usefull also.
close
Message 18 of 29
roland.r71
That actually reminds me i still need to add the option to load the lisp file only ones. as more is not (always) needed.
If it contains a function, which can be called using the supplied script/commands, it would be a waste to load it with each file, as it is still there.
& i better remove the term "lisp" from that script dialog. Before people try pasting complete lisp routines in there. (that won't work). Beyond that it can handle pretty much anything. (script, macro, (command ...), (c:myFunc "test" 1))
... and the help button isn't going to help much (as there's still nothing "behind" it yet 😗)
Time for a version 3.1 😎
Message 19 of 29
john.uhden
My daughter got me a T shirt that reads "If at first you don't succeed,
call it Version 1.0"
John F. Uhden
Message 20 of 29
Sea-Haven
Press the "Any key" top right on my laptop.
