Set QNewTemplate If Statement
ArchD
ArchD
I'm looking to check if the variable "qnewtemplate" is set to a standard template but it gives me an error: ; error: bad argument type: stringp nil
I can't figure it out and I know it's a simple solution. If anyone can help, I'd really appreciate it.
(setq cphQNewTemplate "\\\\cph\\offices\\CADD\\AutoCAD Resources\\_Support-Civil and Landscape\\_Templates\\_cph - (STB) Standard Template (vR21).dwt")
(if
	(not
		(wcmatch
			(getenv "qnewtemplate")
			cphQNewTemplate
	(setenv "qnewtemplate" cphQNewTemplate)
Archie Dodge
Applications Expert - Infrastructure Solutions Division
IMAGINiT Technologies
_gile
You should first check if (getenv "qnewtemplate") is not nil.
(if
  (or (null (getenv "qnewtemplate"))
      (not
        (wcmatch
          cphQNewTemplate
Gilles Chanteau
GileCAD
GitHub
Kent1Cooper
Am I missing something?  If you're going to set it to a new value if it doesn't already match it, it's going to end up with that value in any case, so you may as well just set it that way, without bothering to check whether it matches, or even whether it exists already.  This part alone:
would seem to accomplish what you're after, with the same end result as the longer code, regardless of initial conditions.
Kent Cooper, AIA
ArchD
You are not missing anything. You are absolutely correct. I am a dodo.
I had to use the If Not statement on another part and was in that mode thinking I needed to check everything.
Thanks, I'm off to get some coffee now and think of the weekend.
Archie Dodge
