SET POINT UCS COORDINATE
Message 1 of 15
Hi all Please Help me write Lisp
I want to click a point to enter the UCS value.
Example : Original Coordinate = X = 30.5678 Y = 12.0456 Z = 0.0000
I want to set a new = X = 0.0000 Y = 5000.0000 Z = 0.0000
Replies (14)
Message 2 of 15
marko_ribar
(defun c:oldcoord2newcoord ( / ptw ow vw )
  (setq ptw (trans (getpoint "\nClick on point you want to set coordinates of or specify old coordinates : ") 1 0))
  (setq ow (trans '(0.0 0.0 0.0) 1 0))
  (setq vw (mapcar '- ptw ow))
  (setq ptw (trans (getpoint "\nSpecify new coordinates you wish for clicked point : ") 1 0))
  (vl-cmdf "_.UCS" "_W")
  (vl-cmdf "_.UCS" "_M" "_non" (mapcar '- vw ptw))
  (princ)
HTH., M.R.
Marko Ribar, d.i.a. (graduated engineer of architecture)
Message 3 of 15
@marko_ribar
The result is not correct.
Message 4 of 15
marko_ribar
@Anonymous wrote:
@marko_ribar
The result is correct... I checked it on my AutoCAD...
Message 5 of 15
Kent1Cooper
That is never enough information.  What is not correct about it?
But in the meantime....  @marko_ribar, My UCS command does not show any _M option.  [I'm in Acad2019, but Help for 2021 doesn't describe one, either.]  What is intended?
Kent Cooper, AIA
Message 6 of 15
marko_ribar
"M" - UCS "Move" source origin to destination new point origin...
Of course I assumed that OP's initial UCS was actually WCS... I haven't considered in my code 3D orientation - random UCS...
Message 7 of 15
@marko_ribar
Hi friend
I tried it
When I type 500 but the result is X = -326.6986 Y = -364.4778 Z = 0.000
It should be X = 0.000 Y = 500.000 Z = 0.000
Message 8 of 15
Sea-Haven
When asked for the new co-ords you enter 0,5000,0 and it works for me.
Marko maybe ask X Y Z rather than a point.
For me using multi getvals.lsp
(if (not AH:getvalsm)(load "Multi Getvals.lsp"))
(setq ans (AH:getvalsm (list "New values " "X  " 8 7 "0.0" "Y  " 8 7 "0.0" "Z  " 8 7 "0.0" )))
(setq pt (list (atof (nth 0 ans))(atof (nth 1 ans ))(atof (nth 2 ans))))
(setq ptw (trans pt 1 0))
Message 9 of 15
@Sea-Haven
@marko_ribar
All right!
Can I continue to the next point?
And I always want the X&Z value to be 0
Thank you
Message 10 of 15
lena.talkhina
Welcome to Autodesk Community @Anonymous !
Great to see you here on LISP forum.
Don't hesitate to accept a solution if find one.
Находите сообщения полезными? Поставьте "НРАВИТСЯ" этим сообщениям! | Do you find the posts helpful? "LIKE" these posts!
На ваш вопрос успешно ответили? Нажмите кнопку "УТВЕРДИТЬ РЕШЕНИЕ" | Have your question been answered successfully? Click "ACCEPT SOLUTION" button.
Лена Талхина/Lena Talkhina
Менеджер Сообщества - Русский/Community Manager - Russian
Message 11 of 15
marko_ribar
@Anonymous wrote:
@Sea-Haven
@marko_ribar
All right!
Thank you
I don't know what you are after, but as Alan explained you have to specify all 3 coordinates separated with "," when asked (commas - without quotes)... If you want to continue changing UCS from previous settings and continously set new coordinates, bear in mind that old ones will change... Here is my code slightly modified for working in random UCS, so with this code you may continue with setting coordinates all until you set last point you pick...
(defun c:oldcoord2newcoord ( / pt v )
  (setq pt (getpoint "\nClick on point you want to set coordinates of or specify old coordinates : "))
  (setq v pt)
  (setq pt (getpoint "\nSpecify new coordinates you wish for clicked point : "))
  (vl-cmdf "_.UCS" "_non" (mapcar '- v pt) "")
  (princ)
Hope that now is all fine and satisfies your requests... I changed "M" option as also with my AutoCAD it's not specifed as Kent noticed (it was coded from my experience of working with UCS, not from actuall options provided within command)...
Still I don't quite know why do you need this LISP (if you specify new coordinates, you can as well type them in text you create directly without changing any setting of UCS and this mod. covers only last setting of point coords - it's only better because of general approach that assumes that user works in some random UCS instead of initial AutoCAD default WCS)...
I don't know what else you requested more, I suppose this was correct answer so that you can mark it as soultion...
Am I wrong and missing something more important? You can either way alter my solution to your specific needs to input only single coordinate, but then it won't cover situations that may be more general (all 3 specifications of point data)... We need more info about things explaining what exactly you want to achieve. Then I suppose your input will make some sense - specifications of just Y coordinate... Anyway I leave both explanations and altering provided solution to you...
Stay well and take care.
Regards, M.R.
Message 12 of 15
Sea-Haven
Marko sometimes in CIVIL work will change the ucs from like 67854322.123, 123456.789 to 0,0 and rotate so just makes a bit easier to draft doing PLAN after setting UCS. Makes the text square to orientation etc but the real world co-ords are still there if required. Often for multiple layouts multi ucs to reorient plan view angle.
What is interesting not asking for second point or rotation as well.
Message 13 of 15
@marko_ribar
Hi Friend
  (setq v pt)
  (princ)
When I enter the value 0,5000,0
And I just want to enter the value 5000 only
Sorry, I'm not good at English
Message 14 of 15
marko_ribar
I don't know what do you need this for, but here you are...
(defun c:oldcoord2newcoord ( / pt v Ycoord )
  (setq v pt)
  (setq Ycoord (getreal "\nSpecify Y coordinate ( X = 0.0 ; Z = 0.0 ) : "))
  (setq pt (list 0.0 Ycoord 0.0))
  (princ)
HTH., M.R.
Message 15 of 15
@marko_ribar
Like this
Thank you
