Visual LISP, AutoLISP and General Customization
Github - Autodesk-AutoCAD / AutoLispExt feedback location.
12 REPLIES 12
Message 1 of 13
Bud_Schroeder_ADESK
6760 Views, 12 Replies
We have recently created a Github feedback location where you can share your feedback for the AutoLisp Visual Studio Code Extension.
https://github.com/Autodesk-AutoCAD/AutoLispExt/issues
Thanks in advance for posting your feedback there and we are looking forward to seeing all your great feedback.
Bud Schroeder
AutoCAD Customer Council Beta Programs
Autodesk Inc.
Join the AutoCAD Customer Council Beta Program.
12 REPLIES 12
Message 2 of 13
Hello Bud
Thanks for the Info !
THE HEALTH (Stay Safe), Regards, Patrice (The Old French EE Froggy)
Patrice ( Supporting Troops ) - Autodesk Expert Elite
If you are happy with my answer please mark "Accept as Solution" and if very happy please give me a Kudos (Felicitations) - Thanks
Patrice BRAUD
Message 3 of 13
Thanks Pat and please stay safe as well.
Bud
Bud Schroeder
Autodesk Inc.
Message 4 of 13
add support for Notepad++ please.
Message 5 of 13
Sebastian
Message 6 of 13
hak_vz
in reply to: jtm2020hyo
@jtm2020hyoWhat do you mean by adding support to Notepad++ ?. This is an freeware editor that you can use without special support.
Miljenko Hatlak
Message 7 of 13
I mean, create another extension but for Notepad++. this already was requested for other user in other post related to AutoLisp Extensions
Message 8 of 13
There is a lisp Notepad++ extension already is that what your talking about works great.
; This routine runs the code in the active editor of NotePad++ from AutoCAD:
(defun C:n++ nil (C:RunFromNotePadPP)) ; Quick Run
(defun C:NoteP ( / scr *error* err np++ npeditor npSS npMS r )
; NOTE: Requires ActiveX plugin(by David Gausmann) installed on the NP++
; https://sourceforge.net/projects/nppactivexplugin/
Message 9 of 13
hak_vz
in reply to: Sea-Haven
 @Sea-Haven
Did you mean this
Run code from Notepad++
Miljenko Hatlak
Message 10 of 13
Here we see light to open a great Lisp domain for Advance Steel extensions with Lisps.
We wish we could use the Interop dll from the lisps
https://forums.autodesk.com/t5/visual-lisp-autolisp-and-general/how-to-make-my-own-vla-or-vlax-funct...
Thank you very much @dbroad
I will use these functions from the Advance Steel
For the Current situation it is the Accepted Solutions
For every time for every files we will use these at the starting
(vlax-import-type-library :tlb-filename "C:\\Program Files\\Autodesk\\AutoCAD 2021\\ADVS\\AstorMain5.tlb" :methods-prefix "asm-" :properties-prefix "asg-" :constants-prefix "asc-")
T
660  Objects found  for asm types that is advance steel methods
660 types of Advance Steel constants are found
760 asg types found
Sanjoy Nath
BIM Manager And Digital Lead (Structures Online)
BOOST, AR , VR ,EPM,IFC API,PDF API , CAD API ,Revit API , Advance Steel API
Founder of Geometrifying Trigonometry(C)
Message 11 of 13
Thanks for the information!!!:smiling_face_with_smiling_eyes:
Message 12 of 13
JamesMaeding
in reply to: SanjoyNath
Ah, so that brings up the question - is it full autolisp support in LT?
I can write lisp functions in .net, then call them from regular lisp routine.
I guess that would require the Netload command in LT, which I doubt is there.
Anyway, will LT lisp work with com? (It must, right)
Also, any limitations on a mac? I heard the M processors are good with acad.
thx
internal protected virtual unsafe Human() : mostlyHarmless
I'm just here for the Shelties
Message 13 of 13
Owackenreuther
Thanks for sharing!
AutoCAD Inside the Factory
