Set my Pagesetup "error"
Automohan
Automohan
My pagesetup name = pdf.m-2021
not working !
; pdf.m-2021 - the Page Setup Name
; all - a flag, T for all nil for current layout
(defun SetNamePageSetupAllLayouts (pdf.m-2021 all / lst)
   (or adoc (setq adoc (vla-get-ActiveDocument (vlax-get-acad-object))))
   (if (vl-position
          pdf.m-2021
          (vlax-for pltcfg (vla-get-plotconfigurations adoc)
             (setq lst (cons (vlax-get pltcfg 'pdf.m-2021) lst))
      (progn
         (vlax-for layt (vla-get-Layouts adoc)
            (if (/= (vla-get-name layt) "Model")
               (if all
                  (vla-copyfrom layt (vla-item (vla-get-PlotConfigurations adoc) pdf.m-2021))
                  (if (= (vla-get-name layt) (getvar 'ctab))
         (vla-Regen adoc acActiveViewport)
; to change to MyPagesetup all layouts
(defun c:demo nil
   (SetNamePageSetupAllLayouts "pdf.m-2021" T)
   (princ)
; to change to MyPagesetup just the active layout
(defun c:demo1 nil
   (SetNamePageSetupAllLayouts "pdf.m-2021" nil)
   (princ)
"Save Energy"
Did you find this reply helpful? If so please use the Accept as Solution
Automohan
Remove this Thread !
"Save Energy"
