Delete Duplicates LISP modification
karpki
karpki
attached lisp doesn't work with dynamic blocks
Please make it working if possible
Thanks in advance!
K
Moshe-A
@karpki  hi,
i test it on block "Aluminum Window (Elevation) - Imperial" which i took from ToolsPalette and it worked for me.
can you post a sample dwg?
why don't you use OVERKILL?
Moshe
karpki
Just tested again, after computer was rebooted.
Yes, it works with all the blocks.
Sorry for disturbing!
Regards!
K
karpki
Probably the reason why it works one day and doesn't work another day
cause there is no
(vl-load-com)
in the code.
Why I started using this code instead of OVERKILL, I don't remember exactly , but noticed that it was not perfect killer also in one of the project. So to have two tools is better than one.
Regards
K
