Sequencial numbering
JasonLLINDNER
Message 1 of 11
JasonLLINDNER
Hi
I have this LISP which I'm using for sequential numbering and it runs perfectly ok in AutoCAD Architecture 2016 English ... The problem is when I run it on a different language pack of AutoCAD Architecture 2016 (German and French) ... any ideas how to fix this and get it to run on other LP of ACAD
File attached
PS: Previously posted this on ACA Forum and it was recommended to post question here 🙂
(defun C:arn ()
    (setq a (getstring  T " Enter prefix if any - "))(terpri)
    (setq b (getreal " Starting at number - "))(terpri)
    (setq h(getvar "textsize"))
    (setq c "W")
    (while c
        (setq c (getpoint "position of number -"))(terpri)
        (setq d (rtos b 2 0 ))
        (setq st (strcat a d ))
        (command "_text" "_m" c h "" st )
            (setq b (+ b 1)) )
Replies (10)
Message 2 of 11
BeKirra
What if placing a dot at front of _text? ( i.e. (command "._text" ...
HTH
Please mark "Accept as Solution" and "Like" if my reply resolves the issue and it will help when others need helps.
A circle is the locus of a cursor, starting and ending at the same point on a plane in model space or in layout such that its distance from a given coordinates (X,Y) is always constant.
X² + Y² = C²
Message 3 of 11
JasonLLINDNER
Same ... with or without dot the German and French LP seem to be Messing up with the translation
Message 4 of 11
BeKirra
Can you tell if there is any error message?
X² + Y² = C²
Message 5 of 11
JasonLLINDNER
Would this help?
it adds a Rotation angle 2 degrees instead of getting Default
then assumes text as a command (unknown Command/Befehl)
Message 6 of 11
braudpat
Hello
Welcome to the Autodesk / AutoCAD Forums
1) Your routine "ARN" is OK on a French ACAD !
2) Please check (before running) that your current text style has a Height = ZERO
3) Because the routine FAILS if there is a fixed (NON-ZERO) height !
Regards, Patrice
Patrice ( Supporting Troops ) - Autodesk Expert Elite
If you are happy with my answer please mark "Accept as Solution" and if very happy please give me a Kudos (Felicitations) - Thanks
Patrice BRAUD
Message 7 of 11
pbejse
@JasonLLINDNER wrote:
...any ideas how to fix this and get it to run on other LP of ACAD
Any error message? or it just doesn't do anything?
EDIT: Too late Smiley Very Happy
Message 8 of 11
JasonLLINDNER
@braudpat
I am changing the routines for each LP that was just the one I am using in German... Issue starts with the Drehwink/Angle. Confused cuz it runs perfectly on English (testing in a new blank Default template drawing with all values reseted)
@pbejse
Just the screenshot i pasted above...nothing gets added to the drawing
Message 9 of 11
ВeekeeCZ
I think @braudpat is right. This this code that should fix this.
(defun C:arn ( / a b h c st )
  (setq a (getstring  T "\nEnter prefix <none>: ")
        b (cond ((getreal "\nStarting at number <1>: "))
                (1))
        h (getvar 'TEXTSIZE))
  (while (setq c (getpoint "\nPosition of number <done>: "))
    (setq st (strcat a (rtos b 2 0 ))
          b (1+ b))
    (command "_.TEXT" "_M" c)
    (if (= 0 (cdr (assoc 40 (tblsearch "STYLE" (getvar 'TEXTSTYLE)))))
      (command h))
    (command "" st))
  (princ)
Edited. Last at :55.
Message 10 of 11
pbejse
(command "_.TEXT" "_M" c) (if (= 0 (cdr (assoc 40 (tblsearch "STYLE" (getvar 'TEXTSTYLE))))) (command h)) (command "" st))
Same here, text style issues.
@ВeekeeCZ
While you're at it, do away with command and use ENTMAKEX to completely avoid issues with the different language packs.
Message 11 of 11
ВeekeeCZ
@BeekeeCZ
Sure, it's definitely way to improve the code, little more advanced but independent of the autocad version...
@JasonLLINDNER
Some other improvements added as well.. you to learn from 🙂
(defun c:ARN ( / tmp)
  (or *arn-a*
      (setq *arn-a* ""))
  (or *arn-b*
      (setq *arn-b* 1))
  (setq tmp (getstring T (strcat "\nEnter prefix <" (if (= *arn-a* "") "none" *arn-a*) ">: "))
        *arn-a* (if (= tmp "")
                  *arn-a*
                  tmp)
        *arn-b* (cond ((getint (strcat "\nStart number <" (itoa *arn-b*) ">: ")))
                      (*arn-b*)))
  (while (setq c (getpoint (strcat "\nPlace text '" (strcat *arn-a* (itoa *arn-b*)) "' <done>: ")))
    (entmake (list (cons  00 "TEXT")
                   (cons  10 (trans c 1 0))
                   (cons  11 (trans c 1 0)) 			; must be same as 10, would adjusted automatically
                   (cons  40 (getvar 'TEXTSIZE))
                   (cons  50 (angle '(0 0 0) (getvar 'UCSXDIR)))
                   (cons  01 (strcat *arn-a* (itoa *arn-b*)))
                   (cons  72 4)
                   (cons  73 0)
    (setq *arn-b* (1+ *arn-b*)))
  (princ)
