Hello Everyone,
I need help extracting fractional number in numerical order. as reference, we use a number plus this symbol ~ followed by one of these numbers or symbols "1" "2" "3" "4" "5" "6" "7" "8" "9" "0" " "/" "\"" "q" "w" "e" "r" "t" to denote 1/16" increments. E.g 5~1 = 5 1/16" or 5~2 = 5 1/8" and so on, Thank you for your help. (I'm not an expert on lisp routines, I just self taught enough to do small tweaks)
here is the actual lisp
(defun c:chairbom ()
(setq scalelist '(192.0 128.0 96.0 72.0 48.0 36.0 24.0 16.0 12.0 8.0 1270.0 2540.0 3810.0 5080.0 6350.0 7620.0 8890.0 10160.0 11430.0 12700.0))
;PROGRAM TO READ ATTRIBUTE FILE (C:\ACADWIN\PT\CHAIRBOM.TXT)
;AND TO WRITE A CHAIR BILL-OF-MATERIALS BACK TO DRAWING
(setvar "CMDECHO" 0)
;EXTRACT ATTRIBUTES
(setvar "FILEDIA" 0)
(command "attext" "" "c:\\apps\\PT_CAD\\bom\\chairtem.txt"
"c:\\chairbom.txt")
(prompt "Please wait for processing of attributes")(terpri)
(setvar "FILEDIA" 1)
(prompt "Please wait")(terpri)
(setq a (open "c:\\chairbom.txt" "r"))
(setq charlist
'("1" "2" "3" "4" "5" "6" "7" "8" "9" "0" "~" "/" "\"" "q" "w" "e" "r" "t"))
(setq scale (getvar "dimscale"))
(if (not (member scale scalelist))
(progn
(setq scale (getreal "Enter scale factor - 96 for 1/8\", 128 for 3/32\", 192 for 1/16\" [SCALE FACTOR X 25.4 FOR METRIC]: "))
(setvar "dimscale" scale)
(if (= (cdr (assoc '40 (tblsearch "style" (getvar "textstyle")))) 0.0)
(command "style" "ROMANS" "ROMANS.shx,SPECIAL.shx" (/ (getvar "dimscale") 8.0) 0.9 0 "N" "N" "N")
(setq chrhts '())
(setq alist '())
(listatt)
(close a)
(setq sp (getpoint "Pick starting point for chair schedule: "))
(printatt (length slist) 0 sp)
(setvar "CMDECHO" 1)
(if (/= omo nil)
(setvar "osmode" omo)
(defun listatt ()
(while (setq l (read-line a))
(setq cl (proline l 1 nil nil ""))
(setq lastc (substr (car cl) (strlen (car cl)) 1))
;;;;;;;;;;; REVISION TO PROGRAM ON 2/22/99 TO HANDLE NO QUANTITY CALLOUT IN MULT. CHAIR BLOCK ;;;;;;;
;;;;;;;;;; AND TO CONSOLIDATE CALLOUTS W/ AND W/O INCH MARKS ;;;;;;;
(if (/= lastc "\"")
(progn
(setq htinch (strcat (car cl) "\""))
(setq cl (list htinch (cadr cl)))
(if (= (cadr cl) 0) ;IF QUANTITY IS 0 THEN CHAIR CALLOUT QUANTITY IS TWO
(setq cl (subst 2 0 cl))
;;;;;;; END REVISION ;;;;;;;;;
(if (not (member (car cl) chrhts))
(progn
(setq chrhts (cons (car cl) chrhts))
(setq alist (cons cl alist))
(progn
(setq old (assoc (car cl) alist))
(setq new (append old (cdr cl)))
(setq alist (subst new old alist))
(setq slist '())
(foreach x alist
(setq slist (cons (list (car x) (apply '+ (cdr x))) slist)))
(defun proline (l cn 2f h n / hnl cc )
(setq cc (substr l cn 1))
(cond ((= cn (1+ (strlen l)))
(setq hnl (list h (atoi n)))
((and (member cc charlist) (not 2f))
(if (= h nil)
(setq h cc)
(setq h (strcat h cc))
(proline l (1+ cn) nil h n)
((= cc ",") (proline l (1+ cn) T h n))
((and (member cc charlist) 2f)
(if (= n "")
(setq n cc)
(setq n (strcat n cc))
(T (proline l (1+ cn) 2f h n))
(defun printatt (n i sp)
(setq l (car (nth i slist)))
(command "text" sp 0 l)
(setq l (itoa (cadr (nth i slist))))
(setq np (list (+ (car sp) (* scale 0.75)) (cadr sp)))
(command "text" np 0 l)
(setq sp (list (car sp) (- (cadr sp) (/ scale 3))))
(setq i (1+ i))
(if (< i n) (printatt n i sp))
