Separate Hatches on multiple Layers depending on Color or Name
braudpat
Mentor Mentor
Message 1 of 18
braudpat
Hello
I have not found the magic routine !
Please I need a Lisp routine to separate Hatch depending on Colors or on Names
So I see the routine like :
- Classic ACAD selection
- Keep into the selection ONLY Hatch Object
- Question: Separate by Color (Default) or by Name ?
- Process the 1st Hatch and create (Make Layer) based on the layer hatch "XXXXXX"
==== If Color Separation ====
If standard Color (0-256), Layer Name  : XXXXXX___NNN  (where NNN is 0-256)
( I would like 3 numbers if possible !? )
If RGB Color , Layer Name : XXXXXX___RRR_GGG_BBB
( I would like 3 x 3 numbers if possible !? )
==== If Name Separation ====
Layer name : XXXXXX___ANSI31 , XXXXXX___SOLID , etc
Process the next Hatch ...
Do you see what I mean ? ... Thanks in advance ...
The sample DWG would help you ...
THE HEALTH, Regards, Patrice (The Old French EE Froggy)
I am hidden into my bunker ...
Patrice ( Supporting Troops ) - Autodesk Expert Elite
If you are happy with my answer please mark "Accept as Solution" and if very happy please give me a Kudos (Felicitations) - Thanks
Patrice BRAUD
Replies (17)
Message 2 of 18
dlanorh
Any Color Book colors?
I am not one of the robots you're looking for
Message 3 of 18
dlanorh
1. Does the new layer need a color?
2. Is the hatch to be put on the new layer?
Message 4 of 18
braudpat
Hello
1) YES ALL the Hatch has to be moved to the New Layer
2) What do you mean by color book : Pantone, RAL, etc ?
If YES and if it is not a big effort to manage these special colors :
Create and Use a layer named :  XXXXXX___ColorBookName
3) The NEW layer must have the default Color & LineType & LineWeight of the original hatch layer
4) The moved Hatch have to keep their original color : ByLayer, ByBlock, 0-256, RGB, etc ...
and original LineType and original LineWeight ...
So their new display will be the same before !?
Thanks, Regards, Patrice
Patrice BRAUD
Message 5 of 18
dlanorh
I'm sure this will need tweaking, but try this.
(defun LM:True->RGB ( c ) (mapcar '(lambda ( x ) (lsh (lsh (fix c) x) -24)) '(8 16 24)))
(defun rh:lst2str ( lst del / str) (setq str "")  (mapcar '(lambda (x) (setq str (strcat str x del))) lst) (vl-string-right-trim del str))
(defun rh:layer_props ( lyr lst / v ) (setq v (mapcar '(lambda (x) (vlax-get-property lyr x)) lst)))
(defun c:hatchlayers ( / c_doc c_lyrs l_props ans ss cnt ent elst lyr l_vals hn cstr clst clr nlyr lobj)
  (setq c_doc (vla-get-activedocument (vlax-get-acad-object))
        c_lyrs (vla-get-layers c_doc)
        l_props (list 'truecolor 'linetype 'lineweight)
  );end_setq
  (initget "Color Name")
  (setq ans (cond ( (getkword "\nSeparate Hatches by : [Color/Name] <Color> ")) ("Color")))
  (setq ss (ssget "_X" '((0 . "HATCH"))))
  (cond (ss
          (repeat (setq cnt (sslength ss))
            (setq ent (ssname ss (setq cnt (1- cnt)))
                  elst (entget ent)
                  lyr (cdr (assoc 8 elst))
                  l_vals (rh:layer_props (vla-item c_lyrs lyr) l_props)
                  hn  (cdr (assoc 2 elst))
                  cstr ""
            );end_setq
            (cond ( (= ans "Color")
                    (foreach x '(62 420 430) (setq clst (cons (cdr (assoc x elst)) clst)))
                    (setq clr (vl-some '(lambda (x) x) clst))
                    (cond ( (and (= (type clr) 'INT) (<= clr 256)) (setq cstr (itoa clr))(while (< (strlen cstr) 3) (setq cstr (strcat "0" cstr))))
                          ( (= (type clr) 'STR) (setq cstr clr))
                          (t (setq clr (mapcar 'itoa (LM:True->RGB clr))
                                   clr (mapcar '(lambda (x) (if (< (strlen x) 3) (while (< (strlen x) 3) (setq x (strcat "0" x))) x)) clr)
                                   cstr (rh:lst2str clr "_")
                             );end_setq
                    );end_cond
                    (setq nlyr (strcat lyr "__" cstr))
                  (t (setq nlyr (strcat lyr "__" hn)))
            );end_cond
            (cond ( (not (tblsearch "layer" nlyr)) (setq lobj (vla-add c_lyrs nlyr)) (mapcar '(lambda (x y) (vlax-put-property lobj x y)) l_props l_vals)))
            (vlax-put-property (vlax-ename->vla-object ent) 'layer nlyr)
          );end_repeat
        (t (alert "NO Hatches Found"))
  );end_cond
  (princ)
);end_defun
Message 6 of 18
braudpat
Hello
WAOUH I have to do some other intensive tests with a much more complex DWG !
But the actual routine seems OK ! ... I removed the "_X" to get standard selection ...
Question: if the HATCH Color is ByLayer or ByBlock, I get always 000 !
Is it normal ?? ByBlock is not 256 !?
Thanks, I appreciate your effort ! ... Tomorrow, I will do other tests ...
Beautiful use of mapcar , lambda , etc ... Far beyond my poor Lisp knowledge !
Patrice BRAUD
Message 7 of 18
dlanorh
It should give byblock "000" and bylayer "256". I tested byblock, but not bylayer. I will check tomorrow.
I'm still learning what is possible, but thanks. 😁
Message 8 of 18
dlanorh
Attempt 2. The problem with bylayer was I forgot to allow for the default (no 62 code).
One question, what do you want to do with the hatch boundary (if present)? It's accessable if there.
(defun rh:lst2str ( lst del / str ) (setq str "")  (mapcar '(lambda (x) (setq str (strcat str x del))) lst) (vl-string-right-trim del str))
(defun rh:strlen3 ( str ) (if (< (strlen str) 3) (while (< (strlen str) 3) (setq str (strcat "0" str))) str) str)
        l_props (list 'truecolor 'linetype 'lineweight);Layer properties list
  );end_setq
  (prompt "\nSelect Hatches : ")
  (setq ss (ssget '((0 . "HATCH"))))
  (cond (ss
                  elst (entget ent)
                  lyr (cdr (assoc 8 elst));Layer
                  l_vals (rh:layer_props (vla-item c_lyrs lyr) l_props);Layer properties
                  hn  (cdr (assoc 2 elst));Hatch pattern name
                  cstr ""
                  clst nil
            );end_setq
                    (cond ( (not clr) (setq cstr "256"))                ;No Color set (bylayer)
                          ( (and (= (type clr) 'INT) (<= clr 256))      ;ACI (0-256)
                            (setq cstr (rh:strlen3 (itoa clr)))
                          ( (= (type clr) 'STR) (setq cstr clr))        ;Color Book
                          (t (setq clr (mapcar 'itoa (LM:True->RGB clr));RGB
                                   cstr (rh:lst2str (mapcar 'rh:strlen3 clr) "_")
                             );end_setq
                    );end_cond
            );end_cond
          );end_repeat
  );end_cond
  (princ)
);end_defun
Message 9 of 18
braudpat
Hello @dlanorh
1) BRAVO ! BRAVISSIMO !
2) ByBlock = 000 and ByLayer = 256 !!
3) Even Color Books are OK !!!
4) I have joined my latest DWG Test (more cases) ... For Tests ...
5) What do you mean with Hatch Boundaries ?
If they are present !?
I imagine maybe with 2 new questions !?
5 - Q1) Process Boundaries (Yes/No) - Default = No
5 - Q2) Copy or Move Boundaries (Yes/No) - Default = Copy
Do you think it's possible without big effort !?
Maybe KEEP your effort for others demands because it's not my primary demand !!
THANKS AGAIN, THE HEALTH, Regards, Patrice (The Old French EE Froggy)
Hidden into its bunker
Patrice BRAUD
Message 10 of 18
dlanorh
You can have a hatch without a boundary, if it has been deleted. Finding out if the boundary is there is simple. I was thinking along the lines of changing the boundary to the same layer as the hatch, or copy and change if it is not on the same layer as the hatch.
OK
5.1  Define "Process" Boundaries. Would this be change their layer?
5.2 I don't fully understand this. Please explain in greater detail.
Message 11 of 18
braudpat
Hello
5.1 Process Boundaries (Yes/No) - Default = No
Would this be change their layer ?
5.2 Copy or Move Boundaries (Yes/No) - Default = Copy
I don't fully understand this ... Please explain in greater detail.
---- OOPS SORRY my words were mysterious ! In fact that I imagine is :
- If the Boundary exists, COPY it to the new layer ...
- If the Boundary doesn't exist, RECREATE it to the new layer ...
Please remind that the aspect (of the boundary) must be the same : Color, LineType, LineWeight, Transparency, ...
Do you think it is not too complex to add this feature to YOUR BEAUTIFUL Routine !?
Beware of that into my DWG test , there are ONLY Hatches (No Boundary) ...
Thanks for your attention, THE HEALTH, Regards, Patrice
Patrice BRAUD
Message 12 of 18
dlanorh
OK. I'll see what I can do. Doesn't look too difficult. (touch wood and putting hand to head). 😅
Message 13 of 18
dlanorh
Latest Code. This recreates the boundary on the hatches new layer (where there is no associated boundary), and copies the exiting boundary then moves the original boundary to the hatch layer. Please check that this works a required.
Stay safe.
(defun rh:hatchbound-p (lst) (cadr (mapcar 'cdr (vl-remove-if-not '(lambda (x) (= (car x) 330)) lst))))
(defun rh:rhb (ent lyr) (setvar 'clayer lyr) (command "_.-HATCHEDIT" ent "_B" "_R" "_Y"))
(defun c:hatchlayers ( / *error* c_doc c_lyrs sv_lst sv_vals l_props ans ss cnt ent elst lyr l_vals hn cstr clst clr nlyr lobj b_lst m_lst bobj)
  (defun *error* ( msg )
    (if (and c_doc (= 8 (logand 8 (getvar 'UNDOCTL)))) (vla-endundomark c_doc))
    (mapcar 'setvar sv_lst sv_vals)
    (if (not (wcmatch (strcase msg) "*BREAK*,*CANCEL*,*EXIT*")) (princ (strcat "\nOops an Error : " msg " occurred.")))
    (princ)
  );_end_*error*_defun
        sv_lst (list 'cmdecho 'osmode 'hpbound 'clayer)
        sv_vals (mapcar 'getvar sv_lst)
  );end_setq
  (mapcar 'setvar sv_lst '(0 0 0))
  (cond (ss
          (vla-startundomark c_doc)
                  elst (entget ent)
                  cstr ""
                  clst nil
            );end_setq
                             );end_setq
                    );end_cond
            );end_cond
            (if (= 0 (cdr (assoc 71 elst))) (setq b_lst (cons (list ent nlyr) b_lst)) (setq m_lst (cons (list ent nlyr) m_lst)))
          );end_repeat
          (if b_lst (foreach x b_lst (rh:rhb (car x) (cadr x))))
          (cond (m_lst
                  (foreach y m_lst
                    (setq bobj (vlax-ename->vla-object (cadr (mapcar 'cdr (vl-remove-if-not '(lambda (x) (= (car x) 330)) (entget (car y)))))))
                    (vla-copy bobj)
                    (vlax-put-property bobj 'layer (cadr y))
                  );end_foreach
          );end_cond
  );end_cond
  (vla-regen c_doc acAllViewports)
  (princ)
);end_defun
Message 14 of 18
braudpat
Hello @dlanorh
Please is it possible to ask something a little bit different but very near !
I have joined the version 1.1 of your beautiful routine which separates hatches (without recreating Boudaries) on many layers depending on either Color or either Hatch Name ...
Because I imagine that the new routine will be very similar !?
I would like the same routine to process only for COLOR (So NO question !) but on ANY Entity :
line, arc, 2D pline heavy or light, 3D pline, circle, ellipse, region, spline, mpolygon, text, mtext, mline, dim, hatch, 3DSolid, 3DSurface, 3DFace, 3DPolyMesh, etc ...
Thanks in advance, THE HEALTH (Stay Safe), Regards, Patrice
Patrice BRAUD
Message 15 of 18
dlanorh
I think I understand this, will give it ago over the next couple of days.
Message 16 of 18
braudpat
Hello
Thanks for your future efforts !
Please with a standard ACAD selection : all ACAD entities from the selection on unlocked layers ...
THE HEALTH (Stay Safe), Regards, Patrice (The Old French EE Froggy)
Hidden into my bunker ...
Patrice BRAUD
Message 17 of 18
dlanorh
Initial attempt attached. 😁
Not tested as I only have AutoCAD LT with me at present.
Message 18 of 18
braudpat
Hello Mr @dlanorh
WAOUH Fabulous / Excellent / BRAVO ! ... Your routine is very COMPACT / SHORT !!
I have attached my 2 DWGs :
- ENTITES_2004_1_ORIGINAL  :  the Original Test DWG (with almost ALL entities)
- ENTITES_2004_2_E2LBC  :  the DWG after processing by E2LBC
THANKS, THE HEALTH (Stay Safe), Regards, Patrice
Patrice BRAUD
