SendCommand AutoCAD customization Python
I would like to convert dwg to jpg with python script.
Currently, I am using Export function to convert to bmp, then to jpg
import win32com.client
acad = win32com.client.dynamic.Dispatch("AutoCAD.Application")
doc = acad.ActiveDocument
doc.Export(directory,"bmp", None)
The resolution from export function is quite low, so I would like to use plotter, but I have problem with SendCommand.
doc.SendCommand('_-PLOT ' Y' 'Model ' 'PublishToWeb JPG.pc3 ')
It doesn't work correctly. I know that in VBA SendCommand works with  '& vbCr +'. How to implement SendComand in Python?
Is there another way to optain high resolution?
Sea-Haven
Is it because your -plot is to short
 "-PLOT"  "Y"  "" "DWG To PDF" "Iso full bleed A3 (420.00 x 297.00 MM)" "m" "LANDSCAPE"  "N"   "W"  "-6,-6" "807,560" "1=2"  "C" "y" "Acad.ctb" "Y"	"n" "n" "n" pdfName "N" "y"
