Selection set that goes through a single point
saitoib
Message 1 of 11
saitoib
Hi all!
Can I use ssget to create a selection set that goes through a single point?
Thank you.
Saitoib
Replies (10)
Message 2 of 11
hak_vz
Try to be more specific. What you want to select at that single point?
For a start read this ssget guide from Lee Mac, part about logical filters.
Miljenko Hatlak
Message 3 of 11
ВeekeeCZ
Sure...  (ssget pt)
Message 4 of 11
saitoib
@hak_vz
@ВeekeeCZ
I'm sorry. I didn't explain it well enough.
For example, in the following figure, how can I select the three lines that pass through the point (100 0 0)?
line 0,0 110,0
line 90,0 200,0
line 100,0 100,100
Saitoib
Message 5 of 11
ВeekeeCZ
I typically calculate a small rectangle and use crossing selection.
(ssget "_C" '(99 -1) '(101 1))
Edited: Kent, thx for the heads up.
Message 6 of 11
Kent1Cooper
@ВeekeeCZ wrote:
Sure...  (ssget pt)
That finds only one object.
Kent Cooper, AIA
Message 7 of 11
Kent1Cooper
@ВeekeeCZ wrote:
I typically calculate a small rectangle and use a window selection.
(ssget "_W" '(99 -1) '(101 1))
I think you mean "_C".
Kent Cooper, AIA
Message 8 of 11
Kent1Cooper
@saitoib wrote:
.... in the following figure, how can I select the three lines that pass through the point (100 0 0)?
According to the description in Help for (ssget), this ought to do that:
(setq ss (ssget "_:E" '(100.0 0.0 0.0)))
but for some reason I haven't figured out, it gives me a "bad point argument" error message.
EDIT:  It seems that the :E mode only works with User pick of a point -- see >this< and >here<.
But you can use a Crossing selection without building a larger box, but just use the same point for both corners:
(setq pt '(100.0 0.0 0.0))
(setq ss (ssget "_C" pt pt))
Kent Cooper, AIA
Message 9 of 11
hak_vz
@saitoib wrote:
@hak_vz
@ВeekeeCZ
line 0,0 110,0
line 90,0 200,0
line 100,0 100,100
You didn't read the text at link that I provided. There is actually a sample for similar case.
Miljenko Hatlak
Message 10 of 11
hak_vz
@saitoib wrote:
@hak_vz
@ВeekeeCZ
line 0,0 110,0
line 90,0 200,0
line 100,0 100,100
Command: (setq ss (ssget "c" '(100 0 0) '(100 0 0)))
<Selection set: 10>
Command: M
MOVE
Select objects: !ss
<Selection set: 10>
3 found
Miljenko Hatlak
Message 11 of 11
saitoib
@hak_vz
Thank you very much.
I didn't know there was a way to do this.
I was able to solve the problem.
Saitoib
