Selection of objects list of Properties as txt
Automohan
Automohan
Need lisp for selection of objects list of Properties details export as text file.....
thanks
Automohan
"Save Energy"
Did you find this reply helpful? If so please use the Accept as Solution
ВeekeeCZ
Not sure what you mean. You mean LIST polylines and save it to file?
If so, you can type:
LOGFILEON
LIST
<select objects>
LOGFILEOFF
See LOGFILEPATH to locate your *.log file.
Or other option can be to use THIS Lee's routine.
Automohan
I have a dwg with 50 layouts each layout has 2 viewports (up & down), when I try to select top viewports by filter by X,Y position it is not selecting all 50 nos, means there in some viewports slily moved, I have to go through viewports to check
It's is with 0 Layer, below viewport also 0 layer
otherwise I have to run through each layout & change the above viewport & below viewports to different layers use filter command
Is there any other fast way to select all viewports extract as txt file
(Example: like command: Attout, Attin)
"Save Energy"
ВeekeeCZ
Try this simple one if that would be enough.
(defun c:VPexport (/ ss vd)
  (princ "\nLayout;VPCenterPoint-x;VPCenterPoint-y;Layer")
  (foreach l (layoutlist)
    (if (setq ss (ssget "_X" (list '(0 . "VIEWPORT") (cons 410 l))))
      (repeat (setq i (sslength ss))
        (setq vd (entget (ssname ss (setq i (1- i)))))
        (princ (strcat "\n" l ";" (rtos (cadr (assoc 10 vd)) 2 8) ";" (rtos (caddr (assoc 10 vd)) 2 8) ";" (cdr (assoc 8 vd)))))))
  (princ)
ronjonp
Post your sample drawing. If i'm interpreting the problem correctly this should select the common viewports ( depending on the fuzz value needed for location ).
(defun c:foo (/ f p s ss)
  ;; RJP » 2018-12-13
  ;; Make this number larger if not all are selected
  (setq f 1e-2)
  (cond	((and (setq e (car (entsel "\nPick viewport to filter by location: ")))
	      (setq p (cdr (assoc 10 (entget e))))
	      (setq ss (ssget "_X" '((0 . "VIEWPORT") (-4 . "!=") (69 . 1))))
	 (setq s (mapcar 'cadr (ssnamex ss)))
	 (foreach x s (or (equal p (cdr (assoc 10 (entget x))) f) (ssdel x ss)))
	 (sssetfirst nil ss)
	 (print (strcat (itoa (sslength ss)) " viewports selected"))
  (princ)
Then you can change what you need in the properties palette.
