Select Previous
Select Previous
nbawden
17.721 Vistas
11 Respuestas
Mensaje 1 de 12
Select Previous
nbawden
I regularly use the select previous command manually (i.e. type "select" <enter>  at the command prompt then type "p" <enter><enter>) to recreate the last selection set.
When you run this command you are shown a highlighted preview of the previous selection set after the first <enter> after typing "p"  and after the last <enter> you are left with this active selection set (i.e. grips appear etc)
To speed things up I wanted to add this sequence of commands to the Shorcut Menu "Context menu for default mode" by creating a new command I called "Select Previous" with the macro ^C^Cselect;p;
When I run this command from the shortcut menu I get the preview highlight just like the manual method but when I then hit <enter> I am not given this previous selection set as an active selection - I am left with no selected objects at all.
I notice that Acad had an existing Select Previous command with the macro $M=$(if,$(getvar,cmdactive),,_select;)_p which has the exact same problem as my more basic macro when I try it.
Does anyone know the cause of this difference in functionality between manually typing the command and using either of the two macros?
Soluciones aceptadas (1)
17.722 Vistas
11 Respuestas
Respuestas (11)
Mensaje 2 de 12
Satoews
(defun c:selp (/ ss)
  (setq ss (ssget "_p"))
  (sssetfirst nil ss)
  (princ)
Familiar in how to load lisps? this seems to work in the way i think you want it to.
Just in case you don't know how load lisps, copy and paste lisp into a notepad and save it as whateveryouwant.lsp, then follow this to make it load on startup.
loading a lisp to the startup suite.
Shawn T
Mensaje 3 de 12
hmsilva
Solución aceptada
Try
^C^C_.pselect;_p;;
Hope this helps,
Henrique
Mensaje 4 de 12
Kent1Cooper
@nbawden wrote:
.... I wanted to add this sequence of commands to the Shorcut Menu ... by creating a new command I called "Select Previous" with the macro ^C^Cselect;p;
When I run this command from the shortcut menu I get the preview highlight just like the manual method but when I then hit <enter> I am not given this previous selection set as an active selection - I am left with no selected objects at all. ....
I also was going to suggest including the two semicolons at the end of that macro, though I'm not sure that would function any differently than having only one and then hitting Enter.
But another thing you can try in your macro:
^C^C(sssetfirst nil (ssget "_P"))
Kent Cooper, AIA
Mensaje 5 de 12
ВeekeeCZ
Take the best of suggested:
$M=$(if,$(getvar,cmdactive),,_pselect;)_p;;
...you can apply the previous selection no matter where... Before the command (noun/verb selection) or inside the command (verb/noun selection)-
Mensaje 6 de 12
nbawden
@hmsilva wrote:
Try
^C^C_.pselect;_p;;
Hope this helps,
Henrique
If I simply added another semi colon to the end of my macro it doesn't work - but your macro does thanks
0 Me gusta
Mensaje 7 de 12
hmsilva
@nbawden wrote:
@hmsilva wrote:
Try
^C^C_.pselect;_p;;
Hope this helps,
Henrique
You're welcome, nbawden!
Glad I could help
Henrique
0 Me gusta
Mensaje 8 de 12
prousseauCQJ6U
Gracias, Henrique.
Mensaje 9 de 12
JJUDD_RAAE
exact same problem, this worked for me .
^C^C_.pselect;_p;;
0 Me gusta
Mensaje 10 de 12
lynnetteu
I also used to be able to select previous objects, but not all of a sudden, the selection doesn't become editable after I hit enter. (SELECT --> P --> Enter button)
This might be a workaround:
Type the command PSELECT. At the "Select objects:" prompt, type P (for Previous) and hit enter.
(PSELECT --> P --> Enter button)
Mensaje 11 de 12
cadffm
@lynnetteu
you don't need to post this message every wherem specially not in threads where it is already answered
AND your workflow is wrong, as you can also read above,
the workflow is
PSELECT<enter>P<enter><enter>
Above you can see how to create a command and/or a button for Previous Highlighting
An more about SELECT and PSELECT i wrote to one of your other posts: HERE
Sebastian
0 Me gusta
Mensaje 12 de 12
prousseauCQJ6U
@cadffm Hahah, let a man dream!
(I saw the other post where this guy replied to a 14 years old message :P)
0 Me gusta
