Select one regular block in only one layout
Gorra
Message 1 of 12
Gorra
I feel absurd asking, but I can't seem to get this. I need to select one basic block in a layout as part of a LISP. There is one instance of the block in each layout. I've tried many variations of
(if (setq ss (ssget "_X" '((0 . "INSERT") (2 . "Title Block - To Sheet # anno") (66 . 1))))
  (repeat (1+ (sslength ss))
(setq AdjBlk (ssname ss 0))
or the simpler
(setq insert_sset (ssget "_X" '((0 . "INSERT") (66 . 1) (2 . "Title Block - To Sheet # anno"))))
(setq AdjBlk insert_sset)
or the more complicated
(if (setq insert_sset (ssget "_X" (list (cons 410 LytLbl) '(0 . "INSERT"))))
    (vl-remove-if '(lambda (insert) (/= (strcase "Title Block - To Sheet # anno") (strcase (vla-get-effectivename insert))))
(mapcar 'vlax-ename->vla-object (vl-remove-if 'listp (mapcar 'cadr (ssnamex insert_sset))))
but all I get is a nil value for AdjBlk
If anyone could point out what's probably obvious, I'd appreciate it.
Gorra
Edited to add:
I think I've figured out the problem, the selection is making a selection set, and I've been trying to work with it using list commands.
Replies (11)
Message 2 of 12
paullimapa
The # symbol in the block name is throwing lisp off...try this:
(setq insert_sset (ssget "_X" '((0 . "INSERT") (66 . 1) (2 . "Title Block - To Sheet `# anno")))))
Paul Li
IT Specialist
@The Office
Message 3 of 12
Sea-Haven
You can also add "look in current layout" by using (cons 410  (getvar 'ctab)) in conjunction with other ssget filters.
Message 4 of 12
komondormrex
@Gorra
check it vlaxed,
(setq target_block nil)
(vlax-map-collection (vla-get-block (vla-get-activelayout (vla-get-activedocument (vlax-get-acad-object))))
    '(lambda (object) (if (and (= "AcDbBlockReference" (vla-get-objectname object))
                 (= "Title Block - To Sheet # anno" (vla-get-effectivename object))
              (setq target_block object)
(print target_block)
Message 5 of 12
Gorra
That was indeed part of the problem, thanks
Message 6 of 12
paullimapa
you are welcome...cheers!!!
Paul Li
IT Specialist
@The Office
Message 7 of 12
Gorra
Oh that's what the 410 is for. Thanks
Message 8 of 12
Gorra
Thanks for the method, just need to review it when I have more brain than none
Message 9 of 12
paullimapa
@komondormrex
FYI: there is a typo with this:
(vlax-map-collectiom
but should be:
Paul Li
IT Specialist
@The Office
Message 10 of 12
komondormrex
corrected
Message 11 of 12
komondormrex
@paullimapa
no need to strcat parts of the block name, "Title Block - To Sheet `# anno" will nicely do.
Message 12 of 12
paullimapa
thanks for the feedback. I've revised msg #2
Paul Li
IT Specialist
@The Office
