select last entry in autocad and get elevation (Z)
narasimharaoarza0211
Message 1 of 11
required a lisp program for :
select last entry  in autocad drawing ( Polyline ) and get the " Z " value of the polyline.
Replies (10)
Message 2 of 11
john.uhden
@narasimharaoarza0211
Are you saying that the last object created is a polyline, or do you mean the last polyline created?
Is the polyline always 2D or LWPolyline or maybe a 3D polyline?
If it's 3D do you want the last vertex?  Of course, if it is closed, I think that would be the first vertex.
Does it matter what space it is in?
John F. Uhden
Message 3 of 11
pbejse
What @john.uhden  said.
Message 4 of 11
Kent1Cooper
To add one more "does it matter" question:
Does it matter in what World-or-User Coordinate System the Polyline is drawn, and whether that is the current Coordinate System at the time that you want to get its elevation?  [If you are talking only and always about things drawn in the WCS, never mind the question.]
Kent Cooper, AIA
Message 5 of 11
Kent1Cooper
@narasimharaoarza0211 wrote:
.... select last entry  in autocad drawing ( Polyline ) and get the " Z " value of the polyline.
Come to think of it....
Under what circumstances are you selecting the last entry?  If you want to know immediately after drawing it, without having done anything to it or changed any settings, then a simple (getvar 'elevation) will tell you where you just drew it, without the need to actually select it.  But if you have Moved it vertically since drawing it, that's a different situation [but perhaps still simple, depending on the answers to questions posed so far].
Kent Cooper, AIA
Message 6 of 11
Good morning sir,
It is to further development to:  Offset for 2d or 3d closed polylines (Polygon ) with different horizontal and vertical distance.
It is polygon ( Polyline)  having equal elevation.
While running the program with offset method:
  1. Immediately the last offset polyline should be read out ( Z value) and to be modify to our request.
  2. (getvar 'elevation) is not working  in drawing.
  3. While drawing a rectangle with giving elevation the result is  0.0
Command: _rectang
Current rectangle modes:  Elevation=600.000
Specify first corner point or [Chamfer/Elevation/Fillet/Thickness/Width]: e
Specify the elevation for rectangles <600.000>:
Specify other corner point or [Area/Dimensions/Rotation]:
Command: (getvar 'elevation)
0.0
Command:
Command: LI
LIST 1 found
                  LWPOLYLINE  Layer: "0"
                            Space: Model space
                   Handle = 57bd
            Closed
    Constant width     0.000
              area   18571.563
         perimeter   547.327
          at point  X=370927.361  Y=311284.153  Z=  600.000
          at point  X=371051.890  Y=311284.153  Z=  600.000
          at point  X=371051.890  Y=311135.018  Z=  600.000
          at point  X=370927.361  Y=311135.018  Z=  600.000
Message 7 of 11
hak_vz
Rectangles elevation set in command RECTANGLE is not the value of system variable elevation.
To get elevation of the last rectangle created you can use something like:
(defun rectElev( / eo)
	(cond
		((and
			(setq eo (vlax-ename->vla-object (entlast)))
			(vlax-property-available-p eo 'elevation)
			(vlax-get eo 'elevation)
Miljenko Hatlak
Message 8 of 11
Command: PL
PLINE
Specify start point: 0,0,600
Current line-width is 0.000
Specify next point or [Arc/Halfwidth/Length/Undo/Width]: @10000,10000,600
2D point or option keyword required.
Specify next point or [Arc/Close/Halfwidth/Length/Undo/Width]:
Command:
Command: li
LIST 1 found
Space: Model space
Handle = 57bc
Open
area 0.000
length 2929.431
at point X= 0.000 Y= 0.000 Z= 600.000
at point X= 2044.887 Y= 2097.619 Z= 600.000
Command: *Cancel*
0.0
Message 9 of 11
Kent1Cooper
PLINE won't accept an XYZ point for subsequent vertices [it will for the start point], because they can't have varying elevation.  Give it @10000,10000 without the ,600, and it will be at that elevation.  Then at the end, don't look for the 'elevation System Variable, but for the elevation of the Polyline just drawn:
(getpropertyvalue (entlast) "ELEVATION")
or
(cdr (assoc 38 (entget (entlast))))
Kent Cooper, AIA
Message 10 of 11
OK , Than you very much
Message 11 of 11
Kent1Cooper
You're welcome.  I'm realizing that my advice in Message 5 was based on the assumption that you would have drawn the Polyline at the current Elevation System Variable setting.  That advice is no longer valid if you drew it with a non-zero Z coordinate specified in the start point, as in Message 8.  That forces it to a different elevation from the current Elevation System Variable setting.  That is why I had to suggest looking at something different in Message 9 from what I had suggested in Message 5.
Kent Cooper, AIA
