Good morning sir,
It is to further development to: Offset for 2d or 3d closed polylines (Polygon ) with different horizontal and vertical distance.
It is polygon ( Polyline) having equal elevation.
While running the program with offset method:
- Immediately the last offset polyline should be read out ( Z value) and to be modify to our request.
- (getvar 'elevation) is not working in drawing.
- While drawing a rectangle with giving elevation the result is 0.0
Command: _rectang
Current rectangle modes: Elevation=600.000
Specify first corner point or [Chamfer/Elevation/Fillet/Thickness/Width]: e
Specify the elevation for rectangles <600.000>:
Specify other corner point or [Area/Dimensions/Rotation]:
Command: (getvar 'elevation)
0.0
Command:
Command: LI
LIST 1 found
LWPOLYLINE Layer: "0"
Space: Model space
Handle = 57bd
Closed
Constant width 0.000
area 18571.563
perimeter 547.327
at point X=370927.361 Y=311284.153 Z= 600.000
at point X=371051.890 Y=311284.153 Z= 600.000
at point X=371051.890 Y=311135.018 Z= 600.000
at point X=370927.361 Y=311135.018 Z= 600.000
