Select folder containing dxf and save as dwg
blandb
Mentor Mentor
Message 1 of 21
blandb
I have a company that has folders of dxf files, and they want me to open each dxf and save as dwg. I have the save options set to 2000 format, so I just open all the dxf's in the folder and then do a Zoom Extents > Save > Close....rinse and repeat for the remainder of the drawings open.
Is there a lisp routine that can be done to accomplish this? Select a folder, save the dxf's as the same name just in a dwg format into the same folder the dxf files are?
Thanks in advance
Autodesk Certified Professional
Replies (20)
Message 21 of 21
ec-cad
You probably haven't had time to try out all the possible solutions to DXFOUT, via lisp, so here's a
working model.
Cheers
;; batch_dxf.lsp
 (vl-load-com)
;; Old Version of 'BrowseForFolder' by: Tony Tanzillo (AutoLisp Forum)
(defun BrowseForFolder ( Message / sh folder parentfolder folderobject result)
 (vl-load-com)
  (setq sh
   (vla-getInterfaceObject
     (vlax-get-acad-object)
       "Shell.Application"
   (setq folder
      (vlax-invoke-method
          sh
          'BrowseForFolder
          0
          Message
          0
   (vlax-release-object sh)
    (if folder
      (progn
         (setq parentfolder
           (vlax-get-property folder 'ParentFolder)
        (setq FolderObject
           (vlax-invoke-method
              ParentFolder
               'ParseName
              (vlax-get-property Folder 'Title)
       (setq result
          (vlax-get-property FolderObject 'Path)
       (mapcar 'vlax-release-object
         (list folder parentfolder folderobject)
     (if (/= (substr result (strlen result)) "\\")
       (setq result (strcat result "\\"))
       result
); defun
;; Local Functions to process each DXF to Save as a DWG
 (defun save_the_drawing ( dwg )
  (if (not (findfile dwg))
  (command "_saveas" "2013" dwg); NOTE: you may need to change this line for your version
  ); if
 ); end function save_the_drawing
 (defun do_dwgs ( DXFList )
  (setq L 0)
   (command "_qsave"); save existing drawing opened..
   (repeat (length DXFList)
    (setq dx_fil (nth L DXFList)); get a file at a time
    (setq dwg_fil (substr dx_fil 1 (- (strlen dx_fil) 4))) ; remove the ".dxf" for drawing naming
    (setq dx_fil (strcat DXF_Path_Name dx_fil))
    (command "_erase" "all" "")
    (command "_purge" "ALL" "" "N")
    (command "_DXFIN" dx_fil); load the DXF
    (command "_zoom" "E"); zoom
    (setq dwg_name (strcat DXF_Path_Name dwg_fil))
    (save_the_drawing dwg_name)
    (setq L (+ L 1))
   ); repeat
   (command "_qsave")
   (command)
   (princ)
 ); end function do_dwgs
 (defun get_file_lst ()
  (if (setq DXF_Path_Name (BrowseForFolder "Select Folder of DXF Files."))
   (progn
    (setq fil_lst (vl-directory-files DXF_Path_Name "*.dxf" 1))
     (if (/= fil_lst nil)
      (setq fil_lst (acad_strlsort fil_lst))
      (setq fil_lst (list ""))
     ); end if
   ); progn
  ); if
  (princ)
 ); end function get_file_list
;; Begin
 (setq path (getvar "dwgprefix"))
 (get_file_lst)
 (if fil_lst
   (do_dwgs fil_lst)
 ); if
 (prompt "\nAll DXF Converted to DWG's")
 (princ)
ECCAD
