Select Dynamic Blocks By Name Without Pick First
I'm after a method of selecting all dynamic blocks in the current space so I can delete them programmatically - obviously the name of the block will need to be added to the lisp.
I've managed to find this code from CADTutor but it requires the selection of one instance first.
Would anyone know either what can be changed in this code or maybe have an alternative that selects all versions without a pick first?
Many thanks in advance.
(defun c:sb    (/ e name n out ss x rjp-getblockname)
(vl-load-com)
(prompt "\n   Pick BLOCK to acquire its instances in the drawing...")
  (defun rjp-getblockname (obj)
    (if    (vlax-property-available-p obj 'effectivename)
      (vla-get-effectivename obj)
      (vla-get-name obj)
  (if (setq x     (ssget '((0 . "INSERT")))
        x     (ssname x 0)
        name (rjp-getblockname (vlax-ename->vla-object x))
        ss     (ssget "_X" '((0 . "INSERT")))
        n     -1
        out     (ssadd)
    (while (setq e (ssname ss (setq n (1+ n))))
      (if (= (rjp-getblockname (vlax-ename->vla-object e)) name)
    (ssadd e out)
  (sssetfirst nil out)
  (princ)
ВeekeeCZ
Actually it's easier let the user type a name...
(vl-load-com)
      (vla-get-name obj)))
  (if (setq name   (strcase (getstring T "\nBlock name: "))
            n     -1
            out     (ssadd))
      (if (= (strcase (rjp-getblockname (vlax-ename->vla-object e))) name)
        (ssadd e out))))
  (princ)
That works great, thanks very much - really appreciated.
Sorry in advance but I'm going to be a complete nuisance now - is there a way to hard code in a specific block name for selection instead of the user inserting in a block name?
Many thanks.
ВeekeeCZ
Sure. See the examples of commands. As you can see as the last example, now you can specify more block names delimited by a comma.
(defun c:selBlock1 () 		(selblkbyname "Block1"))
(defun c:selBlock2 () 		(selblkbyname "Block2"))
(defun c:selBlock1and2 () 	(selblkbyname "Block1,Block2"))
(defun selblkbyname (name / e n out ss x rjp-getblockname)
  (if (setq ss     (ssget "_X" '((0 . "INSERT")))
            n     -1
            out     (ssadd))
      (if (wcmatch (rjp-getblockname (vlax-ename->vla-object e)) name)
        (ssadd e out))))
  (princ)
(vl-load-com)
But you don't have to make hard-coded command, you can call the main function with a block name as a parameter:
(selblkbyname "MyBlock")
Have fun!
That sounds great, just what I needed - many thanks again!
