select command not selecting
126843
126843
Hello i have a problem wth select
For example i have slection set ss1
And i want to select this selection set but when i type this in autocad command prompt
(command "select" ss1)
it selects desired objects but prompts me to select more object and when i hit enter or space it deselcts everything.
How to handle this?
Kent1Cooper
The Select command seems to work somewhat different in an AutoLisp (command) function than at the command line.  You can have it all selected/highlighted/gripped this way:
(sssetfirst nil ss1)
Kent Cooper, AIA
ВeekeeCZ
Use the PSELECT command instead of SELECT
Not sure weather you want to add some more objects or not... if not you need to close the selection using "".
(command "_.PSELECT" ss1 "")
john.uhden
Don't use the Select command.  Use (ssget) instead.  And (sssetfirst) is way cool.
Also, if you already have a selection set, then why do you think you need to select it?  Do you go reaching around for a fork that is already in your hand?
John F. Uhden
Ranjit_Singh
@126843 wrote:
......... but when i type this in autocad command prompt
Don't call the auto lisp command function at the command prompt. Simply start the command and at selection prompt type !ss1
Command: SELECT
Select objects: !ss1
<Selection set: 6ba>
1 found
