Select blocks by attribute range
yu85.info
Message 1 of 11
yu85.info
Hello, I have a file (attached) with many blocks. I need to select some of them by a range of a specific attribute (POINT). For exemple 36-56.
Is there a simple way to do this?
Thanks in advance.
Replies (10)
Message 2 of 11
pbejse
Thanks in advance.
(defun c:range ( / ss rl rh range data f numresult i)
       (if (and
	     (setq rl (getint "\nEnter Range (low): "))
	     (setq rh (getint "\nEnter Range (high): "))
	     (setq result (ssadd)
		  ss (ssget "_x" '((0 . "INSERT")(66 . 1))))
	 (progn
	   (setq range (vl-sort  (list rl rh) '<));<-- because some user are really strubborn
	(repeat (setq i (sslength ss))
	  (setq data (mapcar '(lambda (at)
				(cons (vla-get-tagstring at)(vla-get-textstring at)))
				(Vlax-invoke (vlax-ename->vla-object (ssname ss (Setq i (1- i)))) 'GetAttributes)))
	  (and
		(setq f (assoc "POINT" data))
		(numberp (setq num (read (cdr f))))
		(<= (Car range) num (cadr range))
	    	(ssadd (ssname ss i)  result)
  (sssetfirst nil result)
HTH
Message 3 of 11
yu85.info
Thank you very much for your help. I have another question please. If the
name of the block Is A1 and the attribute is POINT, which line in the lisp
I need to change.
Thank you again friend
Message 4 of 11
pbejse
I need to change.
You can remove this [ highlighted in blue ]
(ssget "_x" '((0 . "INSERT")(2 . "POINT")(66 . 1))))
 So it works in any block as long as "POINT" tag is found
HTH
Message 5 of 11
yu85.info
I must done something wrong. This what I inserted but is seems something is
wrong:
(if (and
ss
(progn
strubborn
'GetAttributes)))
(and
(< (Car range) num (cadr range))
Message 6 of 11
pbejse
wrong:
Not the whole line but only this (2 . "POINT")
Anyway, i updated the code at post # 2
HTH
Message 7 of 11
yu85.info
Perfect. Works greate!
LOL
I am a stubborn user 🙂
Thank you!
Message 8 of 11
pbejse
LOL
Thank you!
Well there you go. You are welcome.
Not stubborn, confuse thats all 😉
Message 9 of 11
tauzer_t
This lisp it also suits my needs..but is there easy way to take into account numbers with a suffix ?! Some numbers in the range has a letter in suffix usually letters X and Y.. tia
Message 10 of 11
pbejse
Sure we can, change this
to
(setq num (atoi (cdr f)))
HTH
Message 11 of 11
vladimir_michl
For an example of a complete app, see the SelByAttr freeware tool at:
https://www.cadforum.cz/en/how-to-select-blocks-by-attribute-values-selbyattr-tip13337
Vladimir Michl, www.arkance-systems.cz - www.cadforum.cz
[video]
