Hi guys,
May I have you help please?
In the attached file I have a block called "REVISION" with some tags.
I am looking for a routine that will put in a selection set (ssget) only the instance of this block with the higher string number in the REVB tag.
So, for exemple, In the case of the attached file, it will be the instance with the "3".
Marcelo
