Select block with higher string number
msarqui
msarqui
Hi guys,
May I have you help please?
In the attached file I have a block called "REVISION" with some tags.
I am looking for a routine that will put in a selection set (ssget) only the instance of this block with the higher string number in the REVB tag.
So, for exemple, In the case of the attached file, it will be the instance with the "3".
Marcelo
hmsilva
Hi Marcelo,
as a starting point...
(vl-load-com)
(defun c:demo (/ atts big hnd i obj ss val)
   (if (setq ss (ssget "_X" (list '(0 . "INSERT") '(2 . "REVISION") (cons 410 (getvar 'ctab)) '(66 . 1))))
      (progn
         (repeat (setq i (sslength ss))
            (setq hnd  (ssname ss (setq i (1- i)))
                  obj  (vlax-ename->vla-object hnd)
                  atts (vlax-invoke obj 'GetAttributes)
            (foreach att atts
               (if (and (= (vla-get-TagString att) "REVB")
                        (setq val (vla-get-TextString att))
                        (wcmatch val "#*")
                        (setq val (read val))
                  (cond ((null big)
                         (setq big (cons val hnd))
                        ((and big
                              (> val (car big))
         (if big
            (princ big)
            (princ "\nREVB don't have valid values... ")
      (princ "\nNo REVISION blk was found in the current tab... ")
   (princ)
Hope this helps,
Henrique
marko_ribar
(defun c:selhighestattvaluereference ( / assoclst b )
  (vl-load-com)
  (vlax-for b (vla-get-blocks (vla-get-activedocument (vlax-get-acad-object)))
    (vlax-for a b
      (if (and
            (= (vla-get-objectname a) "AcDbBlockReference")
            (= (vla-get-hasattributes a) :vlax-true)
        (foreach c (safearray-value (variant-value (vla-getattributes a)))
          (if (= (vla-get-tagstring c) "REVB")
            (setq assoclst (cons (cons (vla-get-textstring c) (vlax-vla-object->ename a)) assoclst))
  (if assoclst
    (progn
      (setq b (cdar (vl-sort assoclst '(lambda ( a b ) (> (atoi (car a)) (atoi (car b)))))))
      (sssetfirst nil (ssadd b))
  (princ)
Marko Ribar, d.i.a. (graduated engineer of architecture)
devitg
Hi HMSILVA , as the OP ask to put the inser in a selections set .
I suggest it
(if big
           (progn
            (princ (cdr big))
            (setq insert-ss (ssadd (cdr big)))
            );progn
Could it be so?
msarqui
Many thanks guys!
I can handle from here.
Marcelo
hmsilva
I suggest it
(if big
           (progn
            (princ (cdr big))
            );progn
Could it be so?
Hi Gabriel,
Marcelo (the OP), already have a pretty good level in programming, so I would prefer to just offering him a start to his code, and leave the finalization ti him...
@msarqui
You're welcome, Marcelo
Glad I could help
Henrique
Cheers
Henrique
