Select Block to Place to Points (on same layer)
jhoageN5XUG
jhoageN5XUG
I'm looking for a lisp to allow me to select a block to be placed, and then select a single point.  The block will then be placed onto all points on the same layer as the original selected point.
pendean
Community Legend
Community Legend
jhoageN5XUG
These are close but they place blocks on all the points in the drawing.  I need it to be limited by layer.
jhoageN5XUG
I was able to make a minimal change and it works perfect now, thanks!
calderg1000
Regards @jhoageN5XUG
Try this code...
(defun c:ibp(/ nb sp s i sn pc lpc x)
  (setq nb (getstring "\nEnter Block name: "))
  (if (tblsearch "block" nb)
    (progn
      (setq sp (entget (car (entsel "\nSelect Base Point: ")))
            s  (ssget "a" (list '(0 . "point") (assoc 8 sp)))
      (repeat (setq i (sslength s))
        (setq sn  (entget (ssname s (setq i (1- i))))
              pc  (cdr (assoc 10 sn))
              lpc (cons pc lpc)
      (foreach x lpc
        (entmake (list '(0 . "insert")
                       (cons 2 nb)
                       (cons 10 x)
    (princ "¡¡¡Block Name does Not Exist...!!! ")
  (princ)
Carlos Calderon G
>Did you find this post helpful? Feel free to Like this post.
