Select and fill attributes with predefined values
Message 1 of 15
Hi all,
Can anyone help me to set values for 5 distinct attributes with predefined string values in the LISP code?
Unlike their values, attributes tag names cannot be pre-determined in the code though. That's why I want to be able to select the attribute by a click and get their value updated afterwards. i.e. 1st value (predefined in the code) goes to the first selected ATTRIBUTE, 2nd value (predefined in the code) goes to  second selected ATTRIBUTE and so on.
I should mention some attributes that I select, may not have any value at the moment. I have turned ON the QTEXT value so I can select blank attributes.
Thanks in advance.
Replies (14)
Message 2 of 15
Try NENTSEL.  It's like ENTSEL but instead of returning a list of the main entity's name (if you're clicking on an attribute that would be the entity name of the INSERT to which it's attached) and the pick point it returns the entity name of the selected sub-entity (if you click on an ATTRIB that would be the entity name of the ATTRIB itself) and the pick point.  If I do
(setq return_value (nentsel))
AutoCAD prompts
Select object:
Then when I click on the ELEV attribute of an old-school DCA POINT block in this drawing on my screen it returns this list
(<Entity name: -7d8390> (428227.0 1.29808e+006 0.0))
(car return_value) returns
and (entget (car return_value)) returns the entity data for the POINT attribute:
((-1 . <Entity name: -7d8390>) (0 . "ATTRIB") (330 . <Entity
name: -7d8398>) (5 . "57836") (100 . "AcDbEntity") (67 . 0) (410 . "Model") (8
. "elev") (100 . "AcDbText") (10 428224.0 1.29808e+006 0.0) (40 . 0.8) (1 .
"8.182373") (50 . 0.0) (41 . 1.0) (51 . 0.0) (7 . "S6") (71 . 0) (72 . 0) (11
0.0 0.0 0.0) (210 0.0 0.0 1.0) (100 . "AcDbAttribute") (2 . "ELEV") (70 . 0)
(73 . 0) (74 . 0) (280 . 0))
which you can modify with ENTMOD, as well as reading information from the entity data.
So supposed I want to reset the value of the selected attribute to "101.25".
(defun test()
 (setq attribute_name (car return_value))
 (setq attribute_data (entget attribute_name))
 (setq revised_attribute_data
  (subst
   (cons 1 "101.25")
   (assoc 1 attribute_data)
   attribute_data
 (entmod revised_attribute_data)
 (entupd attribute_name)
The last ENTUPD line is not strictly necessary, as the attribute value was updated by the previous ENTMOD line, but you wouldn't see the change on the screen until you REGEN the drawing.  Also, in a real program you want to do some checking to make sure you selected something and that what you selected was an ATTRIB rather than some other kind of entity.
Message 3 of 15
joselggalan
Can you indicate the string tags of the 5 attributes please..
Message 4 of 15
Ranjit_Singh
maybe something like this
(defun c:somefunc  (/ ctr values attdata)
 (setq ctr 1)
 (repeat 5
  (setq values (cons (getstring t (strcat "\nEnter att" (itoa ctr) " value: ")) values)
        ctr    (1+ ctr)))
 (while (setq ctr 1)
  (mapcar '(lambda (x)
            (and (setq attdata (entget (car (nentsel (strcat "\nSelect tag" (itoa ctr) ": ")))))
                 (= (cdr (assoc 0 attdata)) "ATTRIB")
                 (entmod (subst (cons 1 x) (assoc 1 attdata) attdata)))
            (setq ctr (1+ ctr)))
          (reverse values)))
 (princ))
Message 5 of 15
Assume I want to fill attributes like below:
"0" ----> This value has to be replaced by anything currently sitting on 1st click
"17-03-2017" ----> This value has to be replaced by anything currently sitting on 2ns click
"AS BUILT" ----> This value has to be replaced by anything currently sitting on 3rd click
"JG" ----> This value has to be replaced by anything currently sitting on 4th click
"KV" ----> This value has to be replaced by anything currently sitting on 5th click
Unlike the code provided by Ranjit in Post #4, I don't want to enter String values during run-time. Instead I prefer have them hard coded into the LISP routine beforehand.
Message 6 of 15
Thanks heaps Ranjit. Your code works fine but it has two flaws:
1- It does not break the loop after filling 5th TAG i.e. it keeps asking for TAG1, etc again.
2- I prefer to define string values in the code rather than giving user the option to enter them during run-time.
Message 7 of 15
Thanks W Kiernan. Lessons learnt.
Message 8 of 15
Ranjit_Singh
(defun c:somefunc  (/ attdata ctr)
 (setq ctr 1)
         '("value1" "value2" "value3" "value4" "value5"))
 (princ))
Message 9 of 15
It give me following error on run:
; error: bad argument type: fixnump: nil
Message 10 of 15
Ranjit_Singh
forgot to initialize ctr
 (setq ctr 1)
 (princ))
Message 11 of 15
Thanks Ranjit. It works but 5th TAG is getting ignored  i.e. updates the the first 4 attributes that I click but ignores the fifth one.
Message 12 of 15
Ranjit_Singh
Works at my end. Unless you provide more information it will be difficult to find the cause. Is there an error message?
Message 13 of 15
oops. My bad. The fifth one that I was clicking, was actually a piece of TEXT, not Attribute.
Thanks for your help.
Message 14 of 15
appuraja
I want to explore above point more for one of my requirement.
Actually I having attribute block with Field ROOM1 , ROOM2, ROOM3, ROOM4. When i am inserting this block on my floorplan, i want to insert the Room name in each field just by selecting that respective room text. For example: if my room is having name & number "Store (one text above) 123 (2nd text below)" then i want to fill Store in ROOM1 and 123 in ROOM2.  Can you please provide the script for the same? Thanks in advance
Message 15 of 15
devitg
It will be for better help , if you can upload your sample.dwg
