03:36 AM
- Mute
- Permalink
- Report
Hello All,
I am looking for a LSP file that will help me in selecting only Triangles of a particular Area in a drawing file.
Using QSelect I can select entities with particular areas but that selects other polylines as well which are not required.
Method 2 is uising Qselect again, I can filter out closed entities and then select the triangles by using the same command again. However I am looking for one single command that could help me selecting triangles with a particular area.
This can then be extended to, selecting polygons (side input to be obtained from the user) and then selecting by an property (area, perimeter etc .)
Any help is appreciated. Thank you.
