Select all objects on layers with preset names
mpa-la
mpa-la
Hello all, I have searched, and tried for a couple of hours to write it myself, but alas...  I want a command that selects all the hatches on multiple layers that always have the same name.  Lets call the layers A, B, C, and D.  I want to issue the command, not have to select anything manually, then all the hatches on those layers would get selected and get changed to solid.  I know this is not a terribly complicated lisp, and someone that knows what they're doing could probably write it in 5 minutes!  Can anybody point me at an existing lisp that's similar that I could edit, or make something up quickly for me?  Thanks in advance!!
DC-MWA
I am no guru, but this seems to work.
(defun c:test (/ ss i en)
(if (setq ss (ssget "X" '((0 . "HATCH")(8 . "LayerA,LayerB,LayerC,LayerD"))))
(repeat (setq i (sslength ss))
(setq en (ssname ss (setq i (1- i))))
(command "-hatchedit" en "p" "SOLID")
);repeat
);if
(princ)
hosneyalaa
try
(if (setq ss (ssget "_X" '((0 . "HATCH") )))
  (progn
  (setq objvl (vlax-ename->vla-object en))
  (vla-setPattern objvl acHatchPatternTypePreDefined "SOLID" )
); repeat
); if
(princ)
mpa-la
Hey PC-MWA, that works perfect!!! I can also look at your routine and see where I went astray. Thank you so much!!
mpa-la
Thanks for the routine, but it seems to change all hatches in the drawing to solid.  I need something that targets just the hatches on specified layers, but I can see a use for your routine as well, so I am going to add it to my repertoire!  Thanks so much for looking at that for me!
DC-MWA
You are very welcome Sorry for delay in responding, crazy busy.
devitg
@mpa-la , change to
Where
are yours's layers names  , you  can also use a WILDCAR if layers names have some common letters
(8 . "*A,*B,*C,*D")
