Select a Block at desired location
karthand
karthand
I would like to know if there any way to select a block at a desired co ordinate, purge and delete the objects at an enclosed area.
I have already modified few lisps and was able to figure out the second part, but need help with selecting the block at the given co ordinates.
(defun C:DTTX (/ ss1)
(ssget "C" '((0 . "insert") (10 401 14 0)))
(c:burst)
(if (setq ss1 (ssget "_W" '(395 18) '(410 10) '((0 . "TEXT"))))
(command "_.erase" ss1 "")
(alert "TEXT Not Found")
);; End of if
(princ)
ВeekeeCZ
So you have given an insertion point of some block...
Kent1Cooper
That (ssget) function requires two points between the "C" and the filter list, to define the crossing window.
If you know there will be a Block with its insertion point at that location, change the "C" to an "X".
Kent Cooper, AIA
