How to add coordinate entry into a lisp routine and bypass user input?
matthew_neesley
matthew_neesley
Hello to all:
I have been trying to implement this for a few days, thanks very much to the programmer Lee_Mac:
https://forums.autodesk.com/t5/visual-lisp-autolisp-and-general/insert-dynamic-block-with-visibility...
The code I'm using to actually invoke the insert-a-block functionality is in a separate file, just one line:
(LM:insertwithstate "V1-R3_SI_15BF_24Z_RSL_AUTO" "S0101-NA024215L - 48 length - 24 zones)
The one thing I want to change from the above code is: I get a prompt for where to insert the block.  How can I modify/add to the one line of code above to "hard-code" the automatic entry of values (let's say 0,0,0 for this example) every time, so I don't get any prompts?  Thanks for any responses!
And again...many thanks to Lee_Mac for his extensive coding efforts!
Kent1Cooper
It looks like the routine is already made to put it at 0,0,0.  Might you be getting some unexpected things happening because [as it appears in a quick glance -- no detailed evaluation] you're missing a closing double-quote on the Visibility State name?
Kent Cooper, AIA
matthew_neesley
Interesting...actually, if that's indeed the case, I'd still like to be able to hard-code each individual instance.
I tried this:
(LM:insertwithstate "V1-R3_SI_15BF_24Z_RSL_AUTO" "S0101-NA024215L - 48 length - 24 zones")
(LM:insertwithstate "V1-R3_SI_15BF_24Z_RSL_AUTO" "S0101-NA024415R - 96 length - 24 zones")
...and it does put in both blocks correctly, but it asks for manual placement every time for each block
What I'm trying to do here is automatically place about 580 Visibility States spread across about 35 blocks.  Crazy I know, but I NEED to do this constantly.
If it was set up to indeed place at 0,0,0, then I'd literally need almost 600 different LISPS to place all the blocks automatically.  Make sense?
cadffm
For none programmers
In the vl-cmdf "insert" expression,
"0,0,0" instead "\\"
Sebastian
matthew_neesley
Sorry I don't understand that last reply... ?
Sea-Haven
(vl-cmdf "_.-insert" blk "_S" 1.0 "_R" 0.0 "\\")
