Seek a lisp/python/vba for handle different lisp on specific path with csv format table or/and excel table
skchui6159
skchui6159
Can a lisp/python can handle a list of drawings (may be 1000 drawings) to do different action and load different lisps on a written excel table?
hosneyalaa
Please
More details for your idea
paullimapa
seems like doable function with lisp.
The overall lisp function would rely on Lee Mac's Read CSV lisp to convert the csv contents into lists.
Then create a script file that would open each dwg, run the command, load the lisp, run the function & save the dwg.
My suggestion to make opening & loading of the lisp function easier would be to save the path using either double back slashes "\\" for example:
C:\\Users\\user\\Desktop\\Sample\\Drawing2.dwg,"(command ""_.circle"" (list 5 0) 5)",C:\\Users\\user\\Desktop\\Sample\\AddCircle_A.lsp,(AddCircle_A),Y
or single forward slashes for example:
C:/Users/user/Desktop/Sample/Drawing2.dwg,"(command ""_.circle"" (list 5 0) 5)",C:/Users/user/Desktop/Sample/AddCircle_A.lsp,(AddCircle_A),Y
Paul Li
IT Specialist
@The Office
Sea-Haven
Depending on what you intend doing if it is as simple as making a circle, then you can get Excel to control the CAD and make objects. Using a VBA macro. I have a simple example makes a Line, Pline, circle.
You can use excel to make the script "G2" =CONCATENATE("open ",A2," ",B2," ","save Y") just copy column G to notepad and save as a script .scr file. Limited testing, may need file name in quotes if they have spaces in their names.
skchui6159
@Sea-Haven @paullimapa Thank you, great idea! I will try to write a vba export the copy reference of lisp and then write different condition of lisp. Finally, the wscript from Lee Mac to run the program!
paullimapa
glad to have helped...cheers!!!
Paul Li
IT Specialist
@The Office
Sea-Haven
Your script can have lisp in it, if its only a couple of lines of code do it that way, if lots of code look at the (load "myprogram") have last line matching the defun name to run.
