@skchui6159
check the following code.
; 'add_value_texts' custom command adds value to certain numbers within text strings
; komondormrex, mar, 2025
; totally lm free
(defun string_to_list (string delimiter_string / out_list)
(setq char_list (vl-string->list string))
(defun parse_string (char_list delimiter_string / substring)
(setq char_list_remainder char_list)
(if (vl-some '(lambda (ascii_code)
(setq substring (cons ascii_code substring)
char_list_remainder (cdr char_list_remainder)
(member ascii_code (vl-string->list delimiter_string))
char_list
(progn
(setq delimiter_char (chr (car substring)))
(if (/= "" (setq substring (vl-list->string (reverse (cdr substring)))))
(setq out_list (append out_list (list substring delimiter_char)))
(setq out_list (append out_list (list delimiter_char)))
(parse_string (setq char_list char_list_remainder) delimiter_string)
(if (/= "" (setq substring (vl-list->string (reverse substring))))
(setq out_list (append out_list (list substring)))
out_list
(parse_string char_list delimiter_string)
(defun c:add_value_texts (/ addition text_sset new_text_list do_add old_text_group)
(if (null addition_saved) (setq addition_saved 1))
(if (null (setq addition (getint (strcat "\nEnter addition +-number <" (itoa addition_saved) ">: "))))
(setq addition addition_saved)
(setq addition_saved addition)
(if (setq text_sset (ssget '((0 . "*text") (1 . "*#*"))))
(foreach text (vl-remove-if 'listp (mapcar 'cadr (ssnamex text_sset)))
(setq new_text_list nil do_add nil old_text_group (assoc 1 (entget text)))
(foreach sub_string (string_to_list (cdr (setq old_text_group (assoc 1 (entget text)))) " ,;\\")
(if (and (wcmatch (strcase sub_string) "*SEC*,*TO*")
(null do_add)
(setq do_add t)
(if (and (vl-every '(lambda (asc) (member asc (vl-string->list "0123456789")))
(vl-string->list sub_string)
do_add
(setq new_text_list (append new_text_list (list (itoa (+ (atoi sub_string) addition))))
do_add nil
(setq new_text_list (append new_text_list (list sub_string)))
(entmod (subst (cons 1 (apply 'strcat new_text_list)) old_text_group (entget text)))
(princ)
