Seek a lisp for increment the SEC no.
skchui6159
skchui6159
Can a lisp to increase/decrease the section no. only?
For example (the increment nos. is a variable( integer).
increase 1,
the sec should SEC 9, SEC 10 but (1:25) not change
decrease 1
the sec should 7, SEC 8 but (1:25) not change
komondormrex
@skchui6159
check the following code.
;	'add_value_texts' custom command adds value to certain numbers within text strings
;	komondormrex, mar, 2025
;	totally lm free
(defun string_to_list (string delimiter_string / out_list)
    (setq char_list (vl-string->list string))
  (defun parse_string (char_list delimiter_string / substring)
    (setq char_list_remainder char_list)
    (if (vl-some '(lambda (ascii_code)
              (setq substring (cons ascii_code substring)
                  char_list_remainder (cdr char_list_remainder)
              (member ascii_code (vl-string->list delimiter_string))
              char_list
      (progn
        (setq delimiter_char (chr (car substring)))
          (if (/= "" (setq substring (vl-list->string (reverse (cdr substring)))))
          (setq out_list (append out_list (list substring delimiter_char)))
          (setq out_list (append out_list (list delimiter_char)))
        (parse_string (setq char_list char_list_remainder) delimiter_string)
      (if (/= "" (setq substring (vl-list->string (reverse substring))))
        (setq out_list (append out_list (list substring)))
     out_list
  (parse_string char_list delimiter_string)
(defun c:add_value_texts (/ addition text_sset new_text_list do_add old_text_group)
  (if (null addition_saved) (setq addition_saved 1))
  (if (null (setq addition (getint (strcat "\nEnter addition +-number <" (itoa addition_saved) ">: "))))
	(setq addition addition_saved)
	(setq addition_saved addition)
  (if (setq text_sset (ssget '((0 . "*text") (1 . "*#*"))))
    (foreach text (vl-remove-if 'listp (mapcar 'cadr (ssnamex text_sset)))
      (setq new_text_list nil do_add nil old_text_group (assoc 1 (entget text)))
      (foreach sub_string (string_to_list (cdr (setq old_text_group (assoc 1 (entget text)))) " ,;\\")
        (if (and (wcmatch (strcase sub_string) "*SEC*,*TO*")
                 (null do_add)
            (setq do_add t)
        (if (and (vl-every '(lambda (asc) (member asc (vl-string->list "0123456789")))
                   	    (vl-string->list sub_string)
                 do_add
            (setq new_text_list (append new_text_list (list (itoa (+ (atoi sub_string) addition))))
            	  do_add nil
            (setq new_text_list (append new_text_list (list sub_string)))
      (entmod (subst (cons 1 (apply 'strcat new_text_list)) old_text_group (entget text)))
  (princ)
skchui6159
Exactly Great! Thank you very much for your help!😁👍
