Seek a lisp for extract polygon size and text to csv
skchui6159
Message 1 of 16
skchui6159
How can I get the polygon size (Width and Length) in mm and Wall Mark to csv?
Accepted solutions (3)
Replies (15)
Message 2 of 16
ВeekeeCZ
Possibly like this. Max distance is set to 500. Not exported entities are marked with a circle.
(vl-load-com)
(defun c:WallExport ( / f s i e d l k g r)
  (if (setq f 500 ;; max distance
	    s (ssget '((0 . "TEXT,LWPOLYLINE"))))
    (repeat (setq i (sslength s))
      (setq e (ssname s (setq i (1- i)))
	    d (entget e))
      (if (= "TEXT" (cdr (assoc 0 d)))
	(setq l (cons (cons (cdr (assoc 1 d)) (cdr (assoc 10 d))) l))
	(if (> (cdr (assoc 90 d)) 3)
	  (setq k (cons e k))
	  (setq g (cons (assoc 10 d) g))))))
  (foreach e l
    (setq k (vl-sort k '(lambda (e1 e2) (< (distance (cdr e) (vlax-curve-getclosestpointto e1 (cdr e)))
					   (distance (cdr e) (vlax-curve-getclosestpointto e2 (cdr e)))))))
    (setq c (car k))
    (if (< (distance (cdr e) (vlax-curve-getclosestpointto c (cdr e))) f)
      (setq r (cons (cons (car e) (vl-sort (list (vlax-curve-getdistatparam c 1) (- (vlax-curve-getdistatparam c 2) (vlax-curve-getdistatparam c 1))) '<)) r)
	    k (cdr k))
      (setq g (cons (cons 10 (cdr e)) g))))
  (setq g (append g (mapcar '(lambda (e) (assoc 10 (entget e))) k)))
  (mapcar '(lambda (e) (entmake (list '(0 . "CIRCLE") e (cons 40 f) '(8 . "_ignored")))) g)
  (and r
       (setq f (open (setq p (strcat (getvar "dwgprefix") (getvar "dwgname") "-Export" ".csv")) "w"))
       (foreach e r
	 (write-line (write-line (substr (apply 'strcat (mapcar '(lambda (x) (strcat "," (vl-princ-to-string x)) ) e)) 2)) f))
       (write-line (strcat "Stored at '" p "'")))
  (princ)
Message 3 of 16
skchui6159
Thank you very much!😁.And also, a more question. Can a lisp do automatic dim for above polygon like that?
Message 4 of 16
ВeekeeCZ
Possibly like this
(defun c:DimRectang ( / s d i e v)
  (if (and (setq s (ssget '((0 . "LWPOLYLINE")  (-4 . ">") (90 . 3.))))
	   (setq d (getdist "\nSpecify offset distance: "))
	    v (mapcar '(lambda (x) (trans (getpropertyvalue e "Vertices" x "Position") 0 1)) '(2 3 0)))
      (command "_.dimaligned" "_non" (car v) "_non" (cadr v) "_non" (polar (cadr v) (angle (last v) (cadr v)) d)
	       "_.dimaligned" "_non" (last v) "_non" (cadr v) "_non" (polar (cadr v) (angle (car v) (cadr v)) d))))
  (princ)
Message 5 of 16
skchui6159
@ВeekeeCZ Thank you very much! You solve perfectly! Cheer!
Message 6 of 16
skchui6159
@ВeekeeCZ Sorry, I also find that sometime the polyline shape may not perfectly to 4 points or more than 4 points, closed like that. Can I also use a lisp before wall export/dimrec solve that problem to 4 point ? If not, is also ok😁. I use lee mac program outline.lsp also can not solve that problem...
Message 7 of 16
Sea-Haven
If say you have a 5th point and its aligned correctly then there is code to remove that point so the shape would be 4 corners again. I think Kent Cooper has a solution. If the point has to stay then maybe Kent's code can be used but based on a list of points only. So only end up with a 4 point list.
Message 8 of 16
skchui6159
@Sea-Haven No need to keep that points.
Message 9 of 16
Sea-Haven
You miss understood the comment to do the dims you need at least 3 Points that are calculated from the rectang shape. The solution I have seen removes say 2 pline segments  and replaces with just one segment, so you would have now a 4 segment pline. . I asked "does the 5th point need to be retained". Others will comment based on your answer.
Message 10 of 16
skchui6159
@Sea-Haven  the solution is ok. The 5th point no need to retained.
Message 11 of 16
Sea-Haven
I had problems downloading PLdiet.lsp by Kent Cooper from Cadalyst, I did find another by CadaSchtriumpf.
(defun c:remove-vertex ( / ss objent area_ori vertexlist v_list epoint cnt newlist index indexlist)
 (while (null (setq ss (ssget "_+.:E:S" '((0 . "LWPOLYLINE"))))))
 (and (setq
        objent (vlax-ename->vla-object (ssname ss 0))
        area_ori (vla-get-area objent)
        vertexlist (vlax-get objent "Coordinates")
        v_list vertexlist
      (repeat (/ (length v_list) 2)
         (setq
               epoint (list (car v_list) (cadr v_list))
               cnt     0
               newlist '()
               index   (* 2 (fix (+ 0.5 (vlax-curve-getparamatpoint objent epoint))))
               indexlist (list index (1+ index))
         (foreach ordinate vertexlist
           (if (not (vl-position cnt indexlist))
             (setq newlist (cons ordinate newlist))
           (setq cnt (1+ cnt))
         (not (vl-catch-all-apply 'vlax-put
                (list objent "Coordinates" (reverse newlist))
         (if (equal (vla-get-area objent) area_ori 1E-01); can be 1E-08
          (setq vertexlist (vlax-get objent "Coordinates"))
          (not
              (list objent "Coordinates" vertexlist)
        (setq v_list (cddr v_list))
You need to run the code before doing the DIM.
Message 12 of 16
skchui6159
@Sea-Haven The lisp works great! Thank you very much for your help!😉
Message 13 of 16
skchui6159
If the text , and block is inside the polygon, how can extract the polygon size, text and way of Slab (one way or two way) to csv by lisp.
Message 14 of 16
skchui6159
Can get the content and dimension (length and width) of the above polygon by the lisp?
Message 15 of 16
Sea-Haven
Been discussed many times if you have text inside a closed area you use the text insertion point and use BPOLY then can get all the details of the shape now created.
; Bit of test code
(setq txtins (cdr (assoc 10 (entget (car (entsel "\nPick text "))))))
(command "bpoly" txtins "")
(setq co-ord (mapcar 'cdr (vl-remove-if-not '(lambda (x) (= (car x) 10)) (entget (entlast)))))
(princ co-ord)
Message 16 of 16
skchui6159
Thank you very much! The problem was done. Many Thanks!
