Search Text String
Search Text String
SilentStrike24
Search Text String
SilentStrike24
Hi guys!
Please help me with a small issue.
Is there any free routine that can search a text string in a drawing and then add it in a formula? String is "TOTAL LENGTH:XXX" (XXX is variable) and i need to set dimension text height = XXX value * 0.4
I already set the dimension variables, only text/arrows height needs to be calculated. (see below code)
Thanks in advance!
(defun c:dsq()(command "dimclrt" "7" "" )(command "dimasz" "1" "" )(command "dimtxt" "1" "" )(command "dimclrd" "1" "" )(command "dimclre" "1" "" )(command "dimscale" "1" "" )(command "dimdec" "0" "" )(command "dimtvp" "0.7" "" )(command "dimtih" "OFF" "" )(command "dimtoh" "OFF" "" )(command "dimexo" "0" "" )(command "dimexe" "0.8" "" )(command "dimcen" "2" "" )(command "dimtofl" "ON" "" )(command "dimtfill" "0" "" )(princ))
Kent1Cooper
[Same question as >here<.  Are you the same person with more than one User ID?  This is the better Forum for it, anyway.]
If it's really always exactly as described, then in simplest terms, something like:
(setq
  txt (car (entsel "\nSelect TOTAL LENGTH Text object: "))
  yourTextArrowsHeight (* (atof (vl-string-subst "" "TOTAL LENGTH:" (getpropertyvalue txt "TextString"))) 0.4)
); setq
Kent Cooper, AIA
SilentStrike24
Thanks @Kent1Cooper !
Yes, it is me, twice😁 it was not my intention anyway, first ID was made with an old e-mail address and i forgot the password😁
Thanks for the hint, i'll give it a try!
