search in attributes during mapimport
Message 1 of 8
Hi everyone,
it seems I might need a little help...
I need to import shape files into my drawing. These shape files always have a different name and I cant tell what the name is gonna be (random generated). During the import I change the shp files layer name into one of it's attribute's number. The next part in the importing procedure is when the imported newly named layer is merged to an existing one. The code works just fine.
_$
(defun c:shp ()
(command "._mapimport" "n"
	 		"fólia"
	 		"Adott"
	  		(vl-string-trim ".shp" (strcat "Default:"(getfiled "Válaszd ki az shp fájlokat" "" "shp" 8)))
	  		"fólia"
	 		"adatmezőből"
	 		"v_elhmod"
	 		"adat"
	 		"létrehoz"
	 		"tovább"
	  		"tovább")
(if (tblsearch "Layer" "2")
(progn
(setq OLDLAY "2")
(setq NEWLAY "Opa")
(command "-laymrg" "N" OLDLAY "" "N" NEWLAY "i")))
(if (tblsearch "Layer" "3")
(progn
(setq OLDLAY "3")
(setq NEWLAY "Opa")
(if (tblsearch "Layer" "1")
(progn
(setq OLDLAY "1")
(setq NEWLAY "Opl")
_$
 The problem is that some shp file's attribute data sometimes named V_ELHMOD instead of v_elhmod. So the code works with lowercases. Is there a way to solve this problem? Maybe with a searching code that runs through the attribute table and if it is written with capital letter then return with V_ELHMOD?
Thanks for the answers!
David
Replies (7)
Message 2 of 8
Moshe-A
David,
check (strcase) function (it will do just what you want)
Moshe
Message 3 of 8
Moshe,
the imported shp file's attribute is named (one of it)  v_elhmod or V_ELHMOD. I dont know which one is going to be in the shp file. How can I use strcase in this situation? Mapimport needs a string, the same string that the shp got in the attribute table. Sorry, maybe I was not too clear in my previous letter.
David
Message 4 of 8
dlanorh
Where you are checking the attribute "tag" name use (strcase "tag name"), to always make it uppercase, or conversely use (strcase "tag name" T) to make it always lowercase in the comparison.
I am not one of the robots you're looking for
Message 5 of 8
I did google strcase function, the usage of it is clear :D. If the tag name is always uppercase or lower, it doesnt matter. The problem is that I dont know which one should I use. Because if in the attribute table its lowercase and in my code is always upper, then the code wont work the way I want.
Message 6 of 8
Moshe-A
if you need to know if the string all lowercase or uppercase then write a simple function
to find it.
Message 7 of 8
dlanorh
Post removed
Message 8 of 8
dlanorh
Perhaps your question could be answered better here ->https://forums.autodesk.com/t5/autocad-map-3d-forum/bd-p/85
You can't search the data until it is imported.
