Search for Blocks with special signs in name
info2ERHX
info2ERHX
Hello everyone,
i'm new in this group, either, very new in AutoLisp 🙂
For you for sure simple thing - this simple (i guess:) lisp have to search for blocks in drawing and change Layer according to block name.
Worked fine till blocks with underbars and minus came. I needed to change block name and Layer in code.
Can you please help me modify lisp, to make search for stuff like 'simple_block' and 'simple-block' possible ?
Block's name have to stay unchanged !
Thanks !
Martin.
Code :
(defun c:demo (/ cly ent i lay ss)
  (if (setq ss (ssget "_X" (list '(0 . "INSERT") '(2 . "simple_block") '(66 . 1))))
    (progn
      (setq cly (getvar 'CLAYER))
      (command "_.layer" "_U" "BS" "_T" "BS" "_M" "BS" "")
      (repeat (setq i (sslength sS))
        (setq ent (entget (ssname ss (setq i (1- i))))
              lay (cdr (assoc 8 ent))
        (if (/= lay "BS")
          (entmod (subst (cons 8 "BS") (assoc 8 ent) ent))
      (setvar 'CLAYER cly)
    (prompt "\n \"simple_block\" block not found! ")
  (princ)
cadffm
First i wanted to write:
Read the help about WILDCARDS [F1]
http://help.autodesk.com/view/ACD/2021/ENU/?guid=GUID-E8328DF6-43FF-47AA-8524-72B962A9D552
then i wanted to write about SNVALID [F1]
http://help.autodesk.com/view/ACD/2021/ENU/?guid=GUID-2EFBE198-9860-456B-A090-206C743ACB90
at last i read your code..
"_" and "-" is not a problem. Whatever you problem is, it's not a Blockname with "_" or "-"
Are you sure your block references have Attribures?
You filtering blockreference with Attributes ONLY.
WITH '(66 . 1)
WITHOUT '(66 . 0)
ALL '(66 . 1)
Try your code again with
(setq ss (ssget "_X" (list '(0 . "INSERT") '(2 . "simple_block"))))
or better:
(setq ss (ssget "_X" '((0 . "INSERT") (2 . "simple_block")(8 . "~BS"))))
Then you don't need to check the Layer: (if (/= lay "BS")
and one hint more:
both lines are useless because you doesnt change the CLAYER beteen (in your Demo)
Sebastian
pbejse
First of all, Welcome to the forum
Ssget filter accepts wild card matching
simple?block will match simple-block and simple_block or  simple block, it matches one character between simple and block.
(setq ss (ssget "_X" (list '(0 . "INSERT") '(2 . "simple?block") '(66 . 1))))
Try it
BTW: start fixing your block names 🙂
braudpat
Hello
I am using often this routine "SelBlocks" from BeekeeCZ
To select many different block with the beginning of the name ...
Maybe "SelBlocks" could help you !?
THE HEALTH, Regards, Patrice (The Retired Old French EE Froggy)
Patrice ( Supporting Troops ) - Autodesk Expert Elite
If you are happy with my answer please mark "Accept as Solution" and if very happy please give me a Kudos (Felicitations) - Thanks
Patrice BRAUD
cadffm
After reading it again, my first thought was the right one, but part of the rest are also useful
but it needed some changes <sorry>
Or better on this page: http://help.autodesk.com/view/ACD/2021/ENU/?guid=GUID-EC257AF7-72D4-4B38-99B6-9B09952A53AD
(setq ss (ssget "_X" (list '(0 . "INSERT") '(2 . "simple[_-]block")'(66 . 1))))
or better:
(setq ss (ssget "_X" '((0 . "INSERT") (2 . "simple?block")(8 . "~BS")(66 . 1))))
and one hint more:
both lines are useless because you won't change the CLAYER between (in your Demo)
Use LAYER command option NEW instead of MAKE !
(defun c:demoA (/ cly ent i lay ss)
  (if (setq ss (ssget "_X" (list '(0 . "INSERT") '(2 . "simple[_-]block")'(8 . "~BS")'(66 . 0))))
    (progn
      ;;;(setq cly (getvar 'CLAYER))
      (command "_.layer" "_U" "BS" "_T" "BS" "_NEW" "BS" "") ;<-
        ;;;(if (/= lay "BS")
           (princ "\nDone")
      ;;;(setvar 'CLAYER cly)
    (prompt "\n \"No simple_block&simple-block\" block not found on wrong layers! ")
 (princ)
(defun c:demoB (/ cly ent i lay ss)
  (if (setq ss (ssget "_X" '((0 . "INSERT")(2 . "simple[_-]block")(8 . "~BS")(66 . 1))))
    (progn
      (command "_.layer" "_U" "BS" "_T" "BS" "_N" "BS" "") ;<-
      (command "_.CHPROP" ss "" "_LAYER" "BS" "")
      (princ "\nDone")
 (princ)
R
Sebastian
pbejse
Another
The variable blockAndLayer are your data. that way you can use this for any block name and target layer.
In this example, any of the blockname found under that list, the program will assing the corresponding layer
(("SIMPLE_BLOCK" "SIMPLE-BLOCK" "SIMPLE BLOCK") "ThisLayer" )
(("ANOTHER_BLOCK" "ANOTHER BLOCK" "EVEN A DIFFRENT ONE") "ThisOtherLayer")
You can add as many block names and layer you need.
sor of a catch all thingy.
(defun c:demo (/ blockAndLayer ent bn ThisLAyer)
  (setq	blockAndLayer
	 '((("SIMPLE_BLOCK" "SIMPLE-BLOCK" "SIMPLE BLOCK") "ThisLayer" )
  (if (setq ss (ssget "X" '((0 . "INSERT") (66 . 1))))
	    bn	(strcase (cdr (assoc 2 ent)))
      (if (setq	Thislayer
		 (vl-some '(lambda (bm)
			     (if (member bn (car bm))
			       (cadr bm)
			  blockAndLayer
	(entmod (subst (cons 8 Thislayer) (assoc 8 ent) ent))
  (princ)
HTH
