COMMAND APPLOAD NOT SHOWING/WORKING, LIKE IT NEVER EXISTED
Message 1 of 11
When I text the command  "APPLOAD" it doesn't show any option, not even in the Menu above:
2019 version - Tools - Load Application
2018 version - Manage - Load Application
It's like it doen'st exist... What should I do? Help please!!
Accepted solutions (3)
Replies (10)
Message 2 of 11
cadffm
No error [F2]
after starting command APPLOAD<enter>, you can not draw a line until you hit [ESC] ?
The dialog is offscreen..
follow the link instead of 'SYSVARMONITOR' use your Command APPLOAD
https://forums.autodesk.com/t5/autocad-forum/system-variable-monitor-not-opening/m-p/8685038#M973570
Sebastian
Message 3 of 11
No, it's no offscreen, right after I can draw a line.
It says that "APPLOAD" is an unknown command. I was investigating and people are commenting that are many commands from beforethat are not included in AUTOCAD LT. I even try to apply it from Customize Menu and I can't select the Apply option.
Message 4 of 11
Message 5 of 11
pbejse
If all else fails, short of renstalling Autocad, do a "Reset Settings To Default"
Message 6 of 11
I found the issue. It's the fact that it is AutoCAD LT. It doesn't have some commands, including APPLOAD
Message 7 of 11
pbejse
That made my day @Anonymous
Good for you.
Message 8 of 11
Sea-Haven
At least it was not a MAC. 💻
Message 9 of 11
john.uhden
But I thought there were plenty of Scot offspring down under, like yourself even.  :]
John F. Uhden
Message 10 of 11
trina.jashari
Community Visitor
Community Visitor
So what is the solution? to re-install the app?
Message 11 of 11
cadffm
catmotinha21s program does not offer this command, incl all the related features&posibilities.
Solution: Install a program what offers this feature: AutoCad, not AutoCAD LT
But if you need it for LISP only, you can use AutoCAD LT 2024 too.
Sebastian
