search for a specific attribute and adding a new attribute
Hans_Knol
Hans_Knol
Hi all,
Hope that someone can help me with creating a Lisp file
I need a LISP that can be search to block with a specific attribute called “CN1” or “CN2” “CN*” and after that he search in the drawing to a line that’s horizontal or vertical in the direct area of that Attribute and puts a new hidden attribute with the insertion point at the end of that line. The naming from the new hidden attribute must be “X#TERM##”.
The # means that
  • it must be a 2 when the line is vertical and the attribute is on top of the line
  • it must be a 8 when the line is vertical and the attribute is on top of the line
  • it must be a 1 when the line is horizontal and the attribute is on left site of the line
  • it must be a 4 when the line is horizontal and the attribute is on right site of the line
The ## means that
The number must be the same as the following code of the CN* number where the tool was searching for.
Hans Knol
Hans_Knol
The new attributes must also be on layer 0
Hans Knol
ВeekeeCZ
@Hans_Knol
seems like you did not follow rule number one, therefore you are ignored - you did post a dwg!?
Your description is kinda difficult to follow, posted picture useless - Better make an effort, make nice explanatory examples, possibly the states before and after. The better you do - the better the answer you'll get.
