Search a string for \ character
jwright1962
jwright1962
suppose i have some code:
setq somestring "45'-4\"
(vl-string-position (ascii "\") somestring)
the vl-string-position as shown doesn't work.   wondering how to search a string for \  ?
Kent1Cooper
I don't have AutoCAD on this computer, but I would think one of these should work:
  (ascii "\\")
  (ascii "`\")
EDIT:  But the only reason for the \ in:
  (setq somestring "45'-4\")
would be as an escape character for the inches mark, so it isn't read as the end of the string, in which case it should be:
  (setq somestring "45'-4\"")
with the first " being the inches mark, and the second " ending the string.  But then I believe the \" together are considered one character.  And it may not be possible to find the "position" of the \ alone, with either of my suggestions.
Kent Cooper, AIA
hak_vz
(setq somestring "45'-4\\")
(vl-string-position (ascii "\\") somestring)-> 5
\ symbol is an interupt that is used to let say add new line "\n" or new paragraph "\p"
To present "\" you have to double it.
This will produce an error since parser will keep looking for right parenthesis.  (ascii "''\") won't work.
Miljenko Hatlak
Sea-Haven
Also (vl-string-position 92 somestring)
To find number type (ascii (getstring)) then say \
Kent1Cooper
@Kent1Cooper wrote:
...  But the only reason for the \ in:
... the \" together are considered one character.  And it may not be possible to find the "position" of the \ alone, with either of my suggestions.
If that's the situation, now that I'm on an AutoCAD computer, I can confirm:
returns the feet-and-inches string:
    "45'-4\""
which is what the entity data entry looks like for a Text object with that feet-and-inches content:
Then:
    (vl-string-position (ascii "\"") somestring)
returns the position of the inches mark:
    5
But the backslash does not exist as a character on its own in the string, but only as "part of" the inches mark character.  This:
    (ascii "\\")
is the right way to get the character code for a backslash:
    92
but:
returns
    nil
Kent Cooper, AIA
