script to increase an attribute by 1
neabailey
Message 1 of 8
neabailey
I've got a block "TitleBlock" with an attribute "Revno." that I want to increase by 1. Some drawings have multiple blocks on different layouts so it would need to read and increase all individually simultaneously (some may increase to a 2 and some may increase to a 5 for example. Is That possible?
To clarify I wanted to run a script on a whole project when we rev up, so It will update all drawings.
attached is the block I want the script to edit.
*edited for clarification*
Replies (7)
Message 2 of 8
devitg
@neabaileyYes it is. Please upload your.dwg , and the LSP where you want to apply
Message 3 of 8
neabailey
I added the block dwg, I don't currently have a lisp for this.
Message 4 of 8
Kent1Cooper
The value in that Attribute as posted is 0A, not just a number as one might assume from your description. Would a routine need to deal with that kind of thing [rather more complicated]? If so, what other possibilities are there?
Kent Cooper, AIA
Message 5 of 8
neabailey
@Kent1CooperThe "A" suffix is not really one I need to account for. Its used for "pre-issued" dwgs, so it won't apply to the whole package. The main concern is just Numbers for when ~200 dwgs need to be edited. I should've modified the block before I posted it.
Message 6 of 8
Kent1Cooper
Minimally tested, this seems to do that when inside your drawing [using the actual Block name there]:
(defun C:INCREVNO (/ ss n blk)
  (if (setq ss (ssget "_X" '((0 . "INSERT") (2 . "TBI"))))
    (repeat (setq n (sslength ss)); then
      (setq blk (ssname ss (setq n (1- n))))
      (setpropertyvalue blk "REVNO."
        (itoa (1+ (atoi (getpropertyvalue blk "REVNO."))))
      ); set...
    ); repeat
  ); if
  (prin1)
); defun
The stepping through a bunch of drawings I leave to you to work out with  SCRIPTPRO or other approach, with the Script (load)ing and calling the routine above.
Kent Cooper, AIA
Message 7 of 8
neabailey
@Kent1Cooper  Thank you!!! Works great!
Message 8 of 8
paullimapa
