Script stops running after lisp
djurk_haas
djurk_haas
I have a script (see below) that stops running after the "_Situatie" (Insert_Situatie.lsp).
The lisp "_Situatie" works fine, it's even executed by the script, but is causes to stop running the last part of the script.
I have run the script without the "_Situatie" (Insert_Situatie.lsp) and than it runs fine untill the end so the problm is caused by the lisp  "Insert_Situatie" but I can't figer out why.
Thanks in advance
----Script code-----
_open
"H:\BV3-TRANSMIT\Onderhoek\A\RV CZE A E0000\RV CZE A E0000.dwg"
_Situatie
_Stempel
-----lisp code-----
(defun C:Situatie ()
(command "_insert" "Situatie=E:\\data_tek\\AutoCAD-Custom_JHD\\Algemeen\\Situatie\\Situatie.dwg" nil)
(princ)
cadffm
Do not CANCEL the insert command - Your NIL canceled the command and breaks the script.
Insert the block-reference and delete them.
Sebastian
Kent1Cooper
[Without setting up the situation and experimenting....]
The (command) function always returns nil.  If a nil return "breaks the script," wouldn't any (command) function do so, whether or not it ends with nil internally?
Kent Cooper, AIA
Kent1Cooper
Maybe you can instead use (vl-cmdf), which always returns T.
Kent Cooper, AIA
cadffm
the returning is not the problem
(vl-cmdf) or (command) at the right place will evaluate(? wrong wording) to [ESC]
(command "_insert" "Situatie=E:\\data_tek\\AutoCAD-Custom_JHD\\Algemeen\\Situatie\\Situatie.dwg")
(command) ; or (vl-cmdf)
(princ)
works,
but in 2020 is a bug and iam not sure that it is a problem in this case (an invisible problem which users not seeing in time)
Sebastian
Sea-Haven
A -insert requires name pt X Y rot so where are they ? This will stop a script. You can erase "last" block definition is still in dwg.
cadffm
@Sea-Haven
as i wrote too, but:
What you and me wrotes is just the normal way to ends the command sequence fully.
But if ONLY like to redefining a block in AutoCAD (by hand) you
starts the (classic) INSERT command, choose your DWG,
acknowledge the re-define question and....
Exactly: You don't set the insertion point, scale and rotation and deletes the new blockreference,
you skip the command by pressing [ESC] and you can do this in  Lisp too,  by using the (command) or (vl-cmdf) statement.
____
cadffm schrieb:
..but in 2020 is a bug and iam not sure that it is a problem in this case (an invisible problem which users not seeing in time)
I checked this: It was just a Problem when you want to create a blockreference, but here in this thread we don't want to create a block reference, so it is´also in 2020 not a problem to go this way.
Sebastian
