Script\macro that will delete layers
will.wydock
Message 1 of 11
will.wydock
I am working on a script that I will eventually turn into a macro for my cui. The purpose of the script is to delete certains layers that are in an Architect's Revit export that my engineers never need to see in the files that they use for xrefs. I know that laydel can delete the layer but it will not cycle through if the layers do not exist. Is it possible to do a if layer exists delete it  for a macro/script? If not, how would I handle it within a lisp? see below for the script.
-LAYDEL
n
a-anno-keyn
n
a-anno-dims
n
a-wall-patt
n
g-anno-note
n
g-anno-symb
n
a-wall-iden
n
g-anno-text
n
a-anno-symb
y
-layer
c
8
setbylayer
all
y
y
-overkill
all
d
-purge
all
n
Replies (10)
Message 2 of 11
Ranjit_Singh
Give this a try. Something very basic and can be improved.
(defun c:custlaydel (/ laylst laycollobj)
  (vl-load-com)
  (setq laycollobj (vla-get-layers (vla-get-activedocument (vlax-get-acad-object))))
  (vlax-map-collection laycollobj
                       '(lambda (x) (setq laylst (append (list (vla-get-name x)) laylst)))
  ) ;_ end vlax-map-collection
  (mapcar '(lambda (x)
             (if (member x laylst)
               (command "._-laydel" "n" x "" "")
             ) ;_ end if
           ) ;_ end lambda
          '("a-anno-keyn"       "a-anno-dims"       "a-wall-patt"
            "g-anno-note"       "g-anno-symb"       "a-wall-iden"
            "g-anno-text"       "a-anno-symb"
  ) ;_ end mapcar
) ;_ end defun
Message 3 of 11
Thanks, but when I tried using the routine you sent, I get the response (nil nil nil nil nil nil nil nil).
Message 4 of 11
Ranjit_Singh
Just add a (princ) at the end and you will not get the echo. The routine works though, right?
  (vl-load-com)
               (command-s "._-laydel" "n" x "" "y")
             ) ;_ end if
           ) ;_ end lambda
  ) ;_ end mapcar
(princ)
) ;_ end defun
There was an error. I fixed it. "y" in the command-s
Message 5 of 11
I am no longer getting the nils, however it is not deleting any layers. The file I am testing it on has most of those layers.
Message 6 of 11
Ranjit_Singh
Try the updated routine. I edited it. This was the correction (command-s "._-laydel" "n" x "" "y")
  (vl-load-com)
             ) ;_ end if
           ) ;_ end lambda
  ) ;_ end mapcar
(princ)
) ;_ end defun
Message 7 of 11
hmsilva
Hi Ranjit.Singh
We don't need to get Acad Object, get Active Document, get Layer collection, create a list with all layer nemes in Layer collection, test if layer exist with 'member' that will return a list and if many layers will be slow... testing with vl-position It would be faster...
I would suggest something like this:
(untested)
(defun c:demo nil
    (foreach lay '("a-anno-keyn" "a-anno-dims" "a-wall-patt" "g-anno-note" "g-anno-symb" "a-wall-iden" "g-anno-text" "a-anno-symb")
        (if (tblobjname "layer" lay)
            (command "_.-laydel" "_N" lay "" "_Y")
    (princ)
Hope this helps,
Henrique
Message 8 of 11
Ranjit_Singh
I agree. Using tblobjname is much quicker and concise. I will have to update a few of my routines now 🙂
Message 9 of 11
pramodjoseph
Community Visitor
Community Visitor
Dear all, I need a simple script or lisp file to delete a particular layer called 'M-Rev cloud' . and before deleting the layer I need to change the current layer to '0'.  Thank you.
Message 10 of 11
will.wydock
-layer;set;0;;-laydel;n;M-Rev cloud;;y;
Message 11 of 11
This script works perfectly for finding the listed layers and removing them all. Unfortunately I want to delete a handful of layers but I wont always know the full name of the layer. So instead of changing the script for every file I work on, is there a script to delete multiple layers containing the word "CHANGE"? I know the word "CHANGE" will be common for all projects I work on.
ex of Layers. "CHANGES KIT"
                       "CHANGES"
                        "CHANGES_520"
Also if possible how would I auto run the .lsp for all drawings in my drawing package. Instead of typing appload.... on every drawing individually?
