script - how complete my script
emadelbatran
emadelbatran
Dear friends
My follow sentence it's my script which's I made to edit some attribute values to write new text
OPEN
"P:\Projects 2016\16002 WEDIAN\Elec\Government Zone\SHEETS\DETAILS\P023-CC-EL-09-00-055-C"
_ATTIPEDIT
1155.32805302,309.30755333
as you see i wrote the pass and everything go well , no how I can to insert my text . if somebody help I'll be thanks so much
 Emad
SeeMSixty7
Please note the following solution will work for what you want to do, but there are far more elegant ways to do this.
Try this instead
OPEN
(command "-attedit" "y" "" "" "" "1155.32805302,309.30755333" "" "V" "R" "Here is my new value" "")
The above will change your attribute using attedit rather than a dynamic editor method like attipedit.
The benefit of encompassing it in the "Command" is so that you can see where the returns are. I fyou want to understand what each of the prompts are go through the -attedit command manually.
I would recommend using autolisp to locate the block by name, parse through to the actual attribute then change the attribute at the entity level and then update the inserted block.
Good luck
emadelbatran
thanks a lot for your help SeeMsixty7
SeeMSixty7
You are welcome. I'm glad I could help.
