Script help. How to update a get area script to round up the area to the neares
Message 1 of 8
I have a script that finds an area of a polyline and creates a field that list the area and places the field in the polyline.  My only problem is I would like it to round the field up to the nearest 10 (example 323 would become 330).     See code below
;; local defun
;; get center of closed object
(defun getcenter (obj / acsp cen rgn)
(setq acsp (vla-get-modelspace
	     (vla-get-activedocument
	       (vlax-get-acad-object)))
        rgn (car (vlax-invoke acsp 'Addregion (list obj)))
      cen (vlax-get rgn 'Centroid)
(vla-delete rgn)
cen
;; main part
;; label [plines w]/area field in sq. meters
(defun c:GAREA (/ acsp adoc axss cpt ins ss txt mtxtobj)
  (vl-load-com)
  (or adoc
      (setq adoc (vla-get-activedocument
  (or acsp
		   adoc
  (if
  (setq ss (ssget (list (cons 0 "*POLYLINE,*CONTOUR"))))
  (progn
  (setq axss (vla-get-activeselectionset adoc))
  ;; iterate through the active selection set collection
  (vlax-for obj axss
         ; get a curve center
         (setq cpt (trans (getcenter obj) 0 1))
	 (setq txt
	 ; displayed in meters to 3 decimal place:
;;;		(strcat	"%<\\AcObjProp Object(%<\\_ObjId "
;;;			(itoa (vlax-get obj 'ObjectID))
;;;			">%).Area \\f \"%lu2%pr3%ps[, m2]%ct8[1e-006]\">%"
	 ; displayed in engineering to 2 decimal place:
;			">%).Area \\f \"%pr2%lu2%ct4%qf1\">%");<--pr2 means 2 decimal places, change to your suit
	 ; displayed in engineering to 2 decimal place with addition SQ. FT.:
			(if (vl-string-search "64" (getenv "PROCESSOR_ARCHITECTURE"))
			  (vlax-invoke-method
			    (vla-get-Utility adoc)
			    'GetObjectIdString
			    obj
			    :vlax-false
			  (itoa (vla-get-Objectid obj))
			">%).Area \\f \"%pr0%lu2%ct4%qf1 SF.\">%")
; add mtext object to model space
(setq mtxtobj (vlax-invoke
	       acsp 'AddMText
	       	 cpt ;insertion point
	       0.0 ; mtext width, optional = 0
		txt ;string (field value)
; change mtext height accordingly to current dimension style text height:
;(vlax-put mtxtobj 'Height (getvar "dimtxt")); change (getvar "dimtxt") on text height you need
(vlax-put mtxtobj 'Height "11")
; set justifying to middle center
(vlax-put  mtxtobj  'AttachmentPoint acAttachmentPointMiddleCenter)
     (vla-regen adoc acactiveviewport)
  (princ)
(princ "\n   Type GAREA to label objects with area field")
(princ)
Replies (7)
Message 2 of 8
(setq NN 323)
(setq NN (* (fix (/ NN 10)) 10))
Message 3 of 8
hmsilva
@Anonymous wrote:
(setq NN 323)
I would suggest
(setq NN (* (fix (/ (+ NN 5) 10)) 10))
323 would return 320
325 would return 330
Henrique
Message 4 of 8
Any idea how would I apply this to the code in the OP.  I assume it would need to be applied in this portion of the code.
     (vlax-invoke-method
       'GetObjectIdString
       obj
       :vlax-false
Message 5 of 8
hmsilva
Hello dglenn9000,
unfortunately inches and feet are not my world, I'm a metric guy, I had some difficulty to round up in square feet, probably someone used to using those units will give you better help.
If the outcome was in default units (with no conversion factor) I would use something like this
(strcat "%<\\AcExpr (1e1*trunc(%<\\AcObjProp Object(%<\\_ObjId "
          (vlax-invoke-method
            'GetObjectIdString
            obj
            :vlax-false
        ">%).Area \\f \"%pr0%lu2 \">%*1e-1)) \\f \"%pr0%lu2\">%"
I hope this helps
Henrique
Message 6 of 8
Balaji_Ram
For square feet, please give this a try.
This is similar to what Henrique suggested but since the "round" works on the original value and not on what is previewed, we need to handle the conversion on our own.
   (strcat "%<\\AcExpr (1e1*round((%<\\AcObjProp Object(%<\\_ObjId "
			  (vlax-invoke-method
			    'GetObjectIdString
			    obj
			    :vlax-false
        ">%).Area \\f \"%pr0%lu2\">%/144)*1e-1)) \\f \"%lu2%pr0%ps[, S F (rounded)]\">%")
Balaji
Balaji
Developer Technical Services
Autodesk Developer Network
Message 7 of 8
Balaji_Ram
And here is a test drawing to try it with two mtext inserted.
One of them rounds it to nearest 10 while the other displays without a change.
Cheers,
Balaji
Balaji
Message 8 of 8
A little late in my reply but this works perfect.  Thanks.
