Script for Broken line
I need to write commands for creating Broken(dashed) lines using AutoCAD Scriptfile. Can anyone help me out how to write the command in script file?
Xsk
john.uhden
Won't a dashed or hidden linetype work for you?  If not, then I am guessing that you need the lines and gaps to be of specific lengths, as though you were drawing paint stripes exactly.  Is that the case?  If yes, then how do you handle situations where the whole lengths can not be achieved?  For instance if the line (pen down) were 4 units and the gap (pen up) were 1 unit, then the total length would have to be either 5, 6, 10, 11, etc. in order for them to space out evenly.  Will this apply to arced segments as well, including polylines?  This could get slightly complicated, especially if a vertex were within a pen down length.
I am not aware of Scriptfile.  Is it not available anymore, or just won't work in newer AutoCAD releases?
John F. Uhden
john.uhden
Come to think of it, once PLINEGEN came around, I think I created custom linetypes to make dashed paint lines using polylines.  They were never exact, but looked close enough for construction plans.
John F. Uhden
Thanks for the information.
I used Hidden lines. This is how i wrote the command in script file --
Linetype s HIDDEN
line 0,40 20,80
Linetype s ByLayer
john.uhden
I was never much for AutoCAD scripts, except as simple menu items.
John F. Uhden
Kent1Cooper
@Anonymous wrote:
.... This is how i wrote the command in script file --
Linetype s HIDDEN
line 0,40 20,80
Linetype s ByLayer
Another way you could do that, without changing the current linetype setting and therefore having to change it back, would be to draw the Line and then use CHPROP to change its LType to HIDDEN.
Kent Cooper, AIA
