Lisp for text increment.
I HAVE A SET OF MLEADERS WITH USER BLOCK WITH ATTRIBUTES. I SOMETIMES MISS AN OBJECT THRU TAGGING WHICH I NEED TO ADJUST AGAIN ALL THE NUMBER BY ONE. IS THERE ANY LISP THAT WILL AUTOMATICALLY ADJUST MY NUMBER BY +1 ON ALL THE SAME MLEADER AT THE SAME-TIME. +1(INCREMENT).
DannyNL
Should be fairly easily to code.
Can you post an example drawing with the block as we need to know the attribute tag containing the number.
krzysztof.psujek
easy and dirty but should works for you.
Run it with TRY in cmd - you can change it if you want to.
Lisp was written by LeeMac, I've just modified a little his test part.
;;---------=={ Set MLeader Block Attribute Value }==----------;;
;;  Sets the value of the specified tag for the specified     ;;
;;  MLeader                                                   ;;
;;  Author: Lee McDonnell, 2010                               ;;
;;  Copyright © 2010 by Lee McDonnell, All Rights Reserved.   ;;
;;  Contact: Lee Mac @ TheSwamp.org, CADTutor.net             ;;
;;  Arguments:                                                ;;
;;  mleader - ename/VLA-Object MLeader with attributed block  ;;
;;  tag     - Tagstring of the attribute to change            ;;
;;  value   - Value to which attribute will be set            ;;
;;  Returns:  T if successful, else nil                       ;;
(defun LM:SetMLeaderBlockAttributeValue ( mleader tag value / def id )
  (vl-load-com)
  ;; © Lee Mac 2010
  (if
    (and
      (eq "AcDbMLeader"
        (vla-get-Objectname
          (setq mleader
            (cond
              ( (eq 'VLA-OBJECT (type mleader)) mleader)
              ( (vlax-ename->vla-object mleader) )
      (= 1 (vla-get-ContentType mleader))
      (setq def
        (LM:Itemp
          (vla-get-Blocks
            (vla-get-ActiveDocument
              (vlax-get-acad-object)
          (vla-get-ContentBlockName mleader)
    (if
      (progn
        (vlax-for obj def
          (if (and (eq "AcDbAttributeDefinition" (vla-get-Objectname obj))
                   (eq (strcase tag) (strcase (vla-get-TagString obj))))
            (setq id (vla-get-ObjectID obj))
        id
      (not (vla-SetBlockAttributeValue mleader id value))
;;-----------------------=={ Itemp }==------------------------;;
;;  Retrieves the item with index 'item' if present in the    ;;
;;  specified collection, else nil                            ;;
;;  Arguments:                                                ;;
;;  coll - the VLA Collection Object                          ;;
;;  item - the index of the item to be retrieved              ;;
;;  Returns:  the VLA Object at the specified index, else nil ;;
(defun LM:Itemp ( coll item )
  ;; © Lee Mac 2010
  (if
    (not
      (vl-catch-all-error-p
        (setq item
          (vl-catch-all-apply
            (function vla-item) (list coll item)
    item
(defun c:Try (/ i e); change command here
  (setq i 0)				; enter start number here instead of 0
  (while (setq e (car (entsel "\nSelect MLeader: ")))
    (LM:SetMLeaderBlockAttributeValue e "TAG" (rtos i 2 0));put TAG name which you want to modify here instead of "TAG"
    (setq i (+ 1 i))			;put increment you want here instead of 1
Chris
THIS ONE SIR... (sz. should be no.)
This one works perfect, should be reloaded every number where i start.
Thanks a lot sir. good for my revision as they are adding more valves in drawings. nearly thousand hehehe.
can we set the "0" as a reference value for increment? by selecting/picking
