Script/AutoLISP to convert 3D Solid to 3D Faces
McGrathR1992
McGrathR1992
I am trying to create an automated process to convert all 3D Solids in a dwg to 3D Faces. script if possible but LISP if necessary.
I have noticed the MESHSMOOTH command doesn't properly execute in a script. There are other forum posts on this.
Does anyone have a way to convert this. Thanks.
(Using Basic Autocad 2022)
DGCSCAD
Here's something to get you started:
(defun c:sol2mesh ( / tmp_ss)
(setq tmp_ss (ssget "x" '((0 . "3DSOLID"))))
(command "MESHSMOOTH" tmp_ss "")
(princ)
AutoCad 2018 (full)
Win 11 Pro
hosneyalaa
Can you attached example drawing
