SCALE MULTIPLE TEXT ALONG AN ARC USING THE ARC'S CENTER AS BASE AND A FIXED VALUE TO PROJECT
mohummed.dala
mohummed.dala
Hi all,
i have an arc with many mtext distributed along the arc. the mtext's is set to middle center and has its own geometry x & y.
mathematically the distance between each text geometry and the arc center(not midpoint) is the radius
I need a lisp to scale selected text based on the arc center as basepoint with the new length being radius+1.5 or radius -1.5. So if the length is 10 the new length must be 11.5 and not 15. the same with subtraction type.
im not worried about the change in text height as i can modify that later on.
before
after
ВeekeeCZ
Possibly this could help you.
It moves texts in the direction according to its current angle of rotation.
