scale lsp
scale lsp
nychoe1
Message 1 of 8
scale lsp
nychoe1
hello. I am writting a lsp. it's scale lsp. It works continuously.
if scale value is 0.8. just enter ---> does not working.  what is the problem. some help plz
always thank you all guys
(defun c:saa (/ s1 p1)
(if (= mss nil)
(setq mss 0.8))
(setq dxx (getdist (strcat "\n>> input scale <"(rtos mss 2 2)">: ")))
(if (numberp dxx)(setq mss dxx))
(while
    (setq s1 (ssget ))
    (setq p1 (getpoint "\npick base point:"))
    (command "_.scale" s1 "" p1 dxx )
 (terpri))
(princ)
Replies (7)
Message 2 of 8
Sea-Haven
Just work out the if nil for dxx a press enter.
(if (= dxx nil )(setq  dxx mss)(setq mss dxx))
Message 3 of 8
Moshe-A
@nychoe1 ,
here is a fix
enjoy
moshe
(defun c:saa (/ mss dxx s1 p1)
 (if (not mss)
  (setq mss 0.8)
 (if (not (setq dxx (getdist (strcat "\n>> input scale <<" (rtos mss 2 2)">: "))))
  (setq dxx mss)
 (while (setq s1 (ssget))
  (command "_.scale" s1 "" p1 dxx)
 (princ)
Message 4 of 8
ВeekeeCZ
One step faster version
(defun c:saa (/ dxx s1 p1)
  (or *mss*  				; its global variable
      (setq *mss* 0.8))
  (setq dxx (cond ((getdist (strcat "\n>> input scale <" (rtos *mss* 2 2)">: ")))
                  (*mss*)))
  (while (and (setq s1 (ssget "_:S"))
              (sssetfirst nil s1)
              (setq p1 (getpoint "\npick base point: "))
    (command "_.scale" s1 "" "_non" p1 dxx))
 (princ)
Message 5 of 8
Kent1Cooper
I think all you need to do is to use mss instead of dxx there:
    (command "_.scale" s1 "" p1 mss )
Here's the way I like to do the setting of a variable with a default, which eliminates the need to pre-set it if it doesn't exist, and eliminates the temporary variable [in your case, dxx].  Replace this much:
(if (= mss nil)
(setq mss 0.8))
with this:
(setq mss
  (cond
    ( (getdist
         (strcat "\n>> input scale <" (rtos (cond (mss) (0.8)) 2 2) ">: ")
       ); getdist
    ); User-input condition
    (mss); on Enter with prior value -- keep it
    (0.8); on Enter without prior value [first use]
  ); cond
)' setq
[which isn't as much longer as it looks, if you eliminate the commentary]
(setq mss
  (cond
    ((getdist (strcat "\n>> input scale <" (rtos (cond (mss) (0.8)) 2 2) ">: ")))
    (mss)
    (0.8)
  ); cond
)' setq
Kent Cooper, AIA
Message 6 of 8
ВeekeeCZ
      (setq *mss* 0.8))
  (setq *mss*(cond ((getdist (strcat "\n>> input scale <" (rtos *mss* 2 2)">: ")))
                  (*mss*)))
              (sssetfirst nil s1)
    (command "_.scale" s1 "" "_non" p1 *mss*))
 (princ)
Ou, Kent's right, the variable has to be uniformly *mss*
Message 7 of 8
Kent1Cooper
@Kent1Cooper wrote:
)' setq
[which isn't as much longer as it looks ....
Whoops -- got the next-door key by accident -- that should be:
); setq
in both places.
[And it's actually shorter, just in terms of total code characters.]
Kent Cooper, AIA
Message 8 of 8
nychoe1
tnank you all. I got a lot of help.
