scale and insert
scale and insert
k005
Advisor Advisor
Message 1 of 17
scale and insert
k005
Hi All!
How can I scale the column detail in the example and place it in the drawing on the right.
scale factor here: 0.4
Thanks in advance for the help friend.
We're going to add a change of direction to this...
left-right-down-up
The holding point should be in the center. At the point where we will place it, it should be from the center again. in that part should ask : left ? to the right? down? above?
algorithm example
0- Select the big column
1- Enter the rate. < remember >
2- Small column center ? (calculating...)
3- Left-right-down-up <remember>
4- OK.
Replies (16)
Message 2 of 17
ВeekeeCZ
copybase
pasteclip
s
0.4
When pasting, type S for Scale.
You should post your question HERE There will help you to learn AutoCAD.
Edit: fixed by Kent's remark. Thanks.
Message 3 of 17
Kent1Cooper
@ВeekeeCZ wrote:
clipbase
[I think you mean PASTECLIP.]
Kent Cooper, AIA
Message 4 of 17
k005
@ВeekeeCZ
I think you replied in the wrong place.
When you look at it from there, read the message, do you think I'm new to the forum?
.* The subject is in the right place.
Message 5 of 17
ВeekeeCZ
I was assuming from the phrasing of your question that you're trying to do a process that could be done by built-in commands quite easily. So I've pointed you to the general forums where could advise you on some tips and tricks that you might not know.
Message 6 of 17
k005
I also updated the question, made additions. I wrote hastily, I was at the Construction Site. no problem. 😉
Message 7 of 17
Kent1Cooper
@k005 wrote:
left-right-down-up
algorithm example
4- OK.
1. Can you make the column a Block, to simplify the operation?
2. By "center" do you really mean the center of the column, and not the intersection of the column lines?
3. By "rate" do you mean scale factor?
4. The Text elements are copied but not scaled the way the column elements are, and their positional relationship to the column and also to each other is different in the "after" situation.  Is what you are asking about only for the column elements, or should the Text parts be included, with different calculations about location for those?
5. It seems to me that left-right-up-down is not one choice, but needs a combination -- upper-left, lower-left, upper-right or lower-right, that is, a quadrant relative to the column-line intersection, rather than a single direction.  Or am I misunderstanding the intent.  Can you post a sample drawing showing the results of different choices?
Kent Cooper, AIA
Message 8 of 17
k005
2- Yes column center.
3- Yes scale factor.
4-only column items, that is, the first object group we chose.
There are already columns and texts. their aspects are not important. But the column direction must be exactly the same.
5- So of course it can. I just outlined the algorithm. The most practical method is my acceptance.
Message 9 of 17
hak_vz
@k005
Why don't you create scaled block (or blocks) of column entities with adequately positioned text and copy it around you drawing with changing base point to either column corner?
Miljenko Hatlak
Message 10 of 17
Kent1Cooper
@k005 wrote:
.... But the column direction must be exactly the same. ....
Your RESULT-2 violates that, so something is incomplete about your description.
Also, does the cyan rectangle at bottom right here already exist when you do this?  So should the column elements be copied without the perimeter rectangle?
And in addition to the perimeter being a different color, are the reinforcing parts supposed to be a different color in the result than in the source?
Would the intersection of the blue column lines be the location the User would select for placing the scaled-down copy?  [See the suggestion to use Blocks with insertion points at corners.]
[Not really essential, but....  Where are the reinforcing elements coming from?  Each vertical bar cut through is made up of about 220 independent Lines, and each 90° turn of about 24 Lines.  Can you get them using Solid Hatch patterns or Donut Polylines for the verticals, and Filleted Polylines for the in-plan ones, and so on?  It will greatly reduce the memory consumed, in addition to making "cleaner" plots.]
Kent Cooper, AIA
Message 11 of 17
k005
@hak_vz
It could also be a block. The situation here is that the aspects of the details are given differently. I want to edit them, automatically translate and place them
Message 12 of 17
k005
Yes it will be returned... in result-2
Colors don't matter either... for now.
only change of direction and proportion with scale matter. This is how we will paste it.
that is, I will reduce the column I took from the detail sheet by giving scale and place it on the same direction.
Message 13 of 17
Kent1Cooper
@k005 wrote:
.... I will reduce the column I took from the detail sheet by giving scale and place it on the same direction.
Then I think you're going about it in the wrong way.  You should use Layouts and Viewports, and use different scales in the Viewports to look at the same drawn columns, which should always be drawn once, in Model Space at actual size.  Drawing something at two different model-space sizes for appearance in drawings/details at different scales can only lead to problems.  And whatever your drawing unit represents, I assume you do not specify columns to be built at sizes such as 0.6255 x 3.7465 [meters?].
Kent Cooper, AIA
Message 14 of 17
k005
No . not that way.
like this ;
Detail drawings are on the same dwg sheet. only the scale is different. Drawings-details are in the same file. Just like the example I sent you.
Message 15 of 17
Kent1Cooper
@k005 wrote:
No . not that way.
like this ;
Then I think that's a wrong-enough way to do it that I'm not interested.  Maybe someone else is willing to step in and help.
Kent Cooper, AIA
Message 16 of 17
k005
OK
Message 17 of 17
k005
(defun c:OI ()
(prompt "Açılı ve ölçekli  yapıştır!")
(setvar "cmdecho" 0)
(if (= aci nil)(setq aci 0))
(setq aci_t (getreal (strcat "\nAçıyı Giriniz   <" (rtos aci 2 2)"> : ")))
(if (= aci_t nil)(setq aci_t aci))
(setq aci aci_t)
(if (= oran nil)(setq oran 0.4))
(setq oran_t (getreal (strcat "\nÖlçek Oranını Giriniz   <" (rtos oran 2 2)"> : ")))
(if (= oran_t nil)(setq oran_t oran))
(setq oran oran_t)
(Setq dd (command ".PASTECLIP" "s" oran "R" aci ))
(setvar "cmdecho" 1)
(princ)
(defun c:oı()
(c:OI))
This is how I solved the issue...
